Results 1 to 10 of 16
Thread: Asus A7V 600-X motherboard and 250GB IDE HDD
    N E Somerset
    Default Asus A7V 600-X motherboard and 250GB IDE HDD
    motherboard is almost 3 years old, running 45 + 80GB IDE HDDs. Is there any reason why I would have problems upgrading with a 250GB IDE HDD? Thinking more of it not being able to recognise the full 250 more than anything?
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Shouldn't be a problem I'd have thought, you could check on the Asus website for a BIOS update for it to make sure.
    EDIT: are you actually having problems? What OS? Have you checked in Disk Management to see if appears in there? How are you formatting it?
    N E Somerset
    no, havent bought the 250 yet, just trying to think ahead. o/s = xp sp3.
    N E Somerset
    dont really want to flash the bios if i can avoid it as that is risky isn't it?
    Jun 2006
    Somewhere...
    Can't see a problem, I'd just recommend checking for a BIOS update anyway.
    Jun 2006
    Somewhere...
    Quote Originally Posted by bertxuk View Post
    Can be, but the key is to keep it simple by closing all programs etc beforehand.
    N E Somerset
    on a slightly different slant, but part of the same master plan, presume wont have a problem with a 500GB USB2 external HDD?
    Jun 2006
    Somewhere...
    No problem, the only possible problem could be is if the BIOS boot drive order has USB devices before the IDE drives - easily solved if so by changing the order - as on boot the machine would try to boot from the USB drive.
    Just noticed on the specs for the board that is has SATA ports, why not get a SATA drive instead of the IDE?
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    You should not have any problems at all, most Mobo's support LBA addressing mode and have done for a few years now, so you should be fine. A 250gb drive is not really big these days, it wont be a problem.
    N E Somerset
    Thanks guys,
    reason for not getting sata is cos i wanted to retain control over which disk to boot from, don't sata hdds become the prim boot ahead of any ide drives, i have and want to retain a scond o/s on the other drive which i occasionally boot.
  1. CPU and Motherboard FSB Question...
    By n_hudson in forum The 'Off Topic' room
    Last Post: 13th May 2010, 14:43
  2. MSi Eclipse X58 motherboard
    By bruceybonus in forum General items for sale
    Last Post: 3rd February 2009, 07:38
  3. Replies: 12
    Last Post: 13th January 2008, 13:24
  4. Asus wee
    By shan in forum General Chat
    Last Post: 22nd November 2007, 11:08
