Results 1 to 10 of 23
Thread: Cruise Control
    rhyl
    Default Cruise Control
    hi my Cruise Control dose not work i have tryed the pedle can anyone help me thanks i have a 18 sri
    Blantyre
    Quote Originally Posted by robertuk View Post
    Mine did this the other day, all i did was tap the brake pedal, or put your foot under neath the brake and lift it up , maybe a spring fault or something
    Think this is in the wrong section mate ??
    Unless you spotted a flyer when using cruise control
    Mileage : 000
    I take it you have pressed the brakes once before you use the CC.
    rhyl
    yes i have i dont know what 2 do now
    UK
    Vehicle : Vectra-C
    Trim : sxi
    Engine : 1.9 CDTI
    Try lifting either the clutch or brake pedals with your foot as you engage CC, it could be a dodgy pedal switch as mentioned above. There are switches on both pedals. Also make sure you are above 20 odd mph, as it doesn't work below that speed.
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    Could also be a faulty indicator stalk unit, I had same trouble and after I changed it , it was fine....... I'm sure it is a common problem....
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    i have a used stalk for £15 posted for sale,it did work but had a tendency to switch off,but seemed to fix itself after moving the stalk in and out,there was what looked like a bad connection due to grease but as i had bought a new stalk i decided to use the new stalk
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My used to not work properly. It was dirty contacts in the stalk switches. A spray with electrical cleaner and rapid switching did the job. It now works fine.
    rhyl
    Quote Originally Posted by solorider View Post
    hi what is it like to replace the stalk
    13 Post(s)
    Have you briefly pressed the brake pedal before trying to engage the CC for the first time since the engine's been started?
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
