Thread: Foglight Harness problem..
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Default Foglight Harness problem..
    When I bought my Vectra C damaged the foglight harness was hanging loose and wires were showing. Can this be repaired or will I need a new one? I don't even know where it plugs in, apart from the back of the fogs on the bumper? Any help would be great
    Surrey
    Where is the exposed wire? I would cut the wire where the exposed section is and put heatshrink over one side of the wire. I would solder the wire and put the heatshrink over the join. Depends whether you have a soldering iron or not.
    Feb 2006
    North East Uk
    I do have a soldering iron. I just don't know where the wires go to? The plugs the wires come out of must still be on my car? If I knew the place they plug in I would find the plugs probably. Cheers
    Sunny Dartmoor
    Its a big multi-plug r/h/s of the front bumper by radiator,on mine anyway.....
    Feb 2006
    North East Uk
    Cheers, I will take a look on the weekend. Will my car fail it's mot with this harness not fitted?
  1. abs harness
    By stret in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2013, 21:07
  2. Hid relay harness
    By suggs1971 in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2010, 19:43
  3. Foglight problem
    By steve1975l in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 12:01
  4. wire harness help?
    By HOLDEN in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2006, 20:50
