Results 1 to 10 of 16
Thread: New problem!
    Regular Member djr69uk's Avatar
    Midlands
    Default New problem!
    BOTH electric wing mirrors now operate together when i've got the right hand mirror selection button depressed! That's a good one - I'll add it to the faulty cruise control problem...
    Chester
    Check the manual first. It's supposed to do that.
    lanark
    6 Post(s)
    Year : 2017
    dont think this is a fault mate its designed to do that
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Trim : Elite with sports pack
    Engine : CDTi 150
    Mileage : 103000
    Mileage : 000
    The mirrors are as said above meant to both move together. Seems a bit daft I know. But there must be some reasoning behind it.
    The cruise control, might be a faulty spring on the clutch pedal.
    Quote Originally Posted by Stevel View Post
    PMSL! Classic!
    lanark
    6 Post(s)
    Year : 2017
    how come your smilie is upside down was it on the swally last night
    As the guy's above said, it's normal. On earlier cars each mirror only moved when the relevant switch was depressed - then it changed to the new method.....
    If the outer mirror switch is pressed, the four-way switch operates the driver’s and front passenger’s mirrors and if the inner mirror switch is pressed, it only operates
    the front passenger’s mirror.
    Basically the idea is that once you get both mirrors positioned, if somebody else drives the car and has to move the seat forward/backward then with the right switch depressed both mirrors will move inwards/outwards at the same time to save you doing them separately.
    Chester
    Quote Originally Posted by neverlandandy View Post
    Regular Member mattolly86's Avatar
    oxfordshire
    i thought mine was messed up however i was just going to ignore it and hope it went away lool glad i was set straight
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
