Thread: Signum hatch rattle
    derby
    Angry Signum hatch rattle
    My Signum has been to the dealers three times for hatch rattle and they seem unable to solve the problem!!! In fact following it's last visit a week age it is 10 times worse. Anyway I'm not that technical so have not got a clue what is causing this problem. would have thought Vauxhall trained staff could detect and repair though. Does anyone know what is causing this mind numbing rattle so that i can at least sound like I know what I'm talking about when I take it back in?
    Have you/they tried adjusting the striker plate? Where the tailgate lock locks onto, may need adjusting. You'll see a couple of Torx screws on it that you can loosen it with, and it has little markings on the edge to let you see what position the plate is in. Set it all centred up, then start to make little adjustments forwards and backwards from there. You'll know when you get it right as if you go to far in one direction it'll lock, but not cancel the boot open light, and to far the other way it just won't close.
    That's what I adjusted when I had the same thing at it sorted it.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Are there rubber stops on the outside edge that can be adjusted too?
    Of sorts, but I found that they never really did much to help a rattle - they didn't adjust enough so the striker plate was the only thing that worked for me.
    derby
    Thanks for that guys. Will take it back in, yet again.
  1. Signum - Ski Hatch Broke
    By davyboy in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2010, 13:20
  2. Hatch rattle, faulty latch?
    By mikeopolo in forum Bodywork & Interior
    Last Post: 16th December 2008, 19:45
  3. How big is the signum hatch area?
    By phil67 in forum General Chat
    Last Post: 21st November 2008, 14:29
  4. Signum rattle
    By GSiSnash in forum Bodywork & Interior
    Last Post: 4th January 2008, 17:45
