Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: How do you drain the diesel fuel filter of water
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    Default How do you drain the diesel fuel filter of water
    how do you drain the diesel fuel filter of water? i have a warning light that comes on when you turn on the ignition but goes off when you start the car but sometimes comes on whilst giving the car some welly checked the manual and it says drain the fuel filter any ideas anyone?
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    Well i'm no expert but I would take out the filter, Then get a large syringe with a small length of tubing attached and draw out the water.
    Refill halfway with some deisel and put a new filter in.
    Mine was a ****** to start after changing the deisel filter
    Jon
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Astra Sports Tourer
    Trim : active
    Engine : 1.7cdti
    but when you put filter back in make sure you fill filter housing FULL to the brim HTH
    16 Post(s)
    Year : 2010
    isnt there a drain plug or something
    16 Post(s)
    Year : 2010
    guys??
    May 2006
    scotland
    I read ages ago how to do it. If you go onto the Vauxhall web site and register, I'm sure you can then download all the handbooks for the Vectra C of various vintage years. I seem to remember it was the 2003 addition handbook that gave the procedure and I seem to remember it was as easy as releasing a bleed valve until diesel started to appear.
    It may be water but it may also be a fault in the car electronics. Does your car go into limp home mode i.e feels gutless? If so, its unlikely to be just water in the filter IMO.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The water / fuel separator needs draining periodically. I seem to remember my old Vec B handbook mentioned every 12 months.
    On the bottom of the assembly there was a drain. Loosen the big nut and catch about 1/2 a cup full. That should be more then enough.
    Obviously this relates to the B, so I can't be sure the C is the same, but I would be surprised if it wasn't. The wife's Mazda is also the same, as is every diesel car I've ever seen.
    Water in the fuel filter / separator will happen, that's why it has the separator.
    Regular Member poves's Avatar
    lancashire
    omg guys lol - on the underside of the fuel filter housing there is a drain plug , undo this and let the water drain away until diesel appears - the theory is the diesel will be in the top of the filter as oil floats on water , so the water will be in the bottom of filter anyway.
    Regular Member mattolly86's Avatar
    oxfordshire
    however if you have water in your fuel system light will be on all the time hows your smoke levels sounds like something more sinister to me
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    any pictures? of where to look? dti lumps and cdti lumps please
  1. How to drain fuel filter housing?
    By NoFinPhish in forum Y & Z30DT Specific
    Last Post: 29th November 2012, 20:31
  2. Engine Fault Light - Water in Diesel Fuel Filter?
    By rharris21 in forum Engine & Drivetrain
    Last Post: 14th February 2012, 10:06
  3. cdti Fuel filter drain
    By Derek Mc in forum Diesel Engine related
    Last Post: 2nd October 2010, 16:05
  4. cdti 150 diesel oil filter drain stub
    By veralum in forum Engine & Drivetrain
    Last Post: 12th April 2010, 16:38
  5. diesel filter & prime & drain
    By shatz in forum Engine & Drivetrain
    Last Post: 20th October 2008, 22:18
how to drain water from fuel filter diesel vauxhall vectra
where is vauxhall vectra fuel filter housing
water in diesel fuel filter warning vauxhall vivaro
water in diesel fuel filter vectra
how drain water from fuel filter 1.3 cdti
vauxhall vivaro water in fuel filter
https:www.vectra-c.comforumshowthread.php62570-How-do-you-drain-the-diesel-fuel-filter-of-water
what draws fuel to filter on astra h 1.9 cdti
water in fuel filter vivaro
how to drain water from vauxhall signum cdti fuel filter
how to empty water from fuel filter vauxhall astra
vectra 1.9 cdti water in fuel
dieselfilter vectra c
vauxhall vectra fuel filter water drain
drain water from signum fuel filter
insignia water in diesel filter
how to release water from diesel fuel filter corsa c 13 cdti
2005 zafira fuel filter warning light
saab 93 water in fuel change fuel filter
vauxhall fuel filter water
removing water from my vauxhall zafira diesel filter
drain filter diesel Vauxhall combo
movano fuel filter diesel drain
vectra c fuel filter housing drain
corsa d 1.3 cdti removing water from fuel filter
