Results 1 to 10 of 13
Thread: repairing rear heated window?
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    Default repairing rear heated window?
    Hi all,
    I have an annoying single bar that does not work on the rear heated window right in the middle
    I have had a very close look and can see a miniscule area of the element that looks damaged.
    Is there anything on the market that you can recomend that might be able to to repair this
    Jon
    lanark
    6 Post(s)
    Year : 2017
    on an old car i used a very thin strip of tin foil dont know if that will work with modern cars
    Surrey
    Buy the pen to join the tracks. I have seen a few of these failing recently...must be the time of year.
    Seer Green, Bucks
    Just been searching on google and the pen seems a good bet.
    I have just bought a cheap multimeter to pin point the break just in case its not where I thought it was.
    Will let you know how successful I am with the repair
    Jon
    Surrey
    You should of taken a picture of where you think was broken. Zoomed in a bit to find the break.
    Regular Member Lump's Avatar
    coventry
    yeh let me know how it goes as i have a line out
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    i have used a paint like stuff from halfords before and that was fine
    Regular Member mark_w's Avatar
    cheshire
    use some conductive paint from RS components, the type used for small/minor repairs to circuit boards.
    http://uk.rs-online.com/web/search/s...hTerm=101-5621
    Jun 2007
    Black Country
    Quote Originally Posted by mark_w View Post
    Ive used this stuff before and its VERY good, just make sure you use masking tape either side of the line, and shake the bottle for at least a week to mix it up, paint it on, then leave for an hour and go over it again to make sure its cured fully
    also you will need to clean the area with white spirit first to get a good connection
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    can second how good this stuff is. not used it for a window but used some to repair a psp slim other day. worked a treat and to be honest i doubted if it would work on something so fildy
  1. Rear heated window puzzle
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2012, 16:00
  2. Heated rear window
    By Guss in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2011, 13:28
  3. Heated Rear Window
    By si_hoss in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2009, 15:03
  4. Rear heated window
    By BigP in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2006, 20:15
