Results 1 to 10 of 16
Thread: Side light fault.. HELP
    Regular Member jared.ryder's Avatar
    Jun 2007
    NORFOLK
    Default Side light fault.. HELP
    Hi guys i have just fitted a set of LED side light bulbs but now i have a fault reading on the dash. also when the side lights are switched off they flash intermittantly about once every three seconds.. any1 got any ideas why this is happening. and what i can do to sort it out..
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 103000
    leds dont work in the Vectra
    but there is a fix some think to do with a resistor
    Jun 2007
    NORFOLK
    Quote Originally Posted by Thunder View Post
    They work perfectly when they are switched on and they only flash when they are off, for about 10mins they stop so is somthing i could live with its just the dash warning that was annoying me most..
    Sheffield
    I've just found this out myself. After going through some slight discomfort in changing the dipped beams for night breakers, i thought i'd change the side lights for the free LED ones that came with the night breakers.
    All that effort, sliced arms and swearing to find the flipping things cause an error!
    The worst bit was knowing i'd have to put the standard bulbs back.
    Oh well
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If you go to maplins and buy 2 resistors (item L22R) and wire them across the s/light wires, they will cure your problems,well they have on mine, but you know how finicky a vec-c can be!
    Jun 2007
    NORFOLK
    Quote Originally Posted by Martin177 View Post
    Oh well
    did you notice thet yours flash when u fist un-lock / lock the car for about 10mins.. looks pretty cool in the dark when parked.. lol looks like some kind of gucci alam.. lol
    Jun 2007
    NORFOLK
    Quote Originally Posted by tyreman View Post
    If you go to maplins and buy 2 resistors (item L22R) and wire them across the s/light wires, they will cure your problems.
    wiked nice 1 mate
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    With the the resistors i still get the s/lights flash when the car is unlocked, but the main thing is the display doesn't show a warning with the engine running.
    Yeah you will do as the car is still pulsing a small current through the lighting circuit. The resistor only gives the car the resistance its looking for so it doesn't think a lamp has blown - the led's have a much lower resistance than the filiment lamps.
    Regular Member stuee's Avatar
    witney near oxford ish
    yea so if their is less resistance it finds a fault. i got the same problem i bought a set of HID'S and their alot less power than standard bulbs so always reads a fault does my head in. but u can buy a warning cancellor as far as im aware???
  1. LED side Light Fault
    By Phatomdog in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 12:05
  2. Passenger side wiper fault
    By antowns in forum General Chat
    Last Post: 8th December 2009, 01:18
  3. Parking light/side light
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2009, 11:14
  4. TC AND ABS LIGHT Serious Fault
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2008, 19:49
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
