Thread: Erratic CANBUS
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default Erratic CANBUS
    Hi
    Looking for advice on the following.....
    Recently replaced the rear indicator bulbs as the orange coating had came away.After this, I started to get an intermitent warning a rear light bulb failure.All the bulbs appeared fine so I cleaned up all the contacts on the cluster - still the same.Eventually changed all the bulbs.This seemed to cure it....until I started to get warnings for the LHS bulbs(previously had been the RHS!),then the RHS again !!! wtf? AS soon as it alarms and I click 'ok' the alarm clears and the warning symbol disappears from the dash.Really stuck here.Its as if it is trying to make me go off my head.At this point,I am not far away from doing this!!!
    Any advice?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Take the hole cluster out and clean all the contacts and plug, that should it mate.
    North London
    I have a Signum where the off side rear indicator blinks a couple of time after powering up then stops working. I had a tech 2 scan which suprisingly indicated open circuit OSR indicator. I tried a holder bulb and rear body control module and guess what it still dont work!
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    with tech2 it reads live data. So the possibility exists to leave it powered up, try things and watch the readings at the same time.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Could this be a poor quality bulb scenario?????
    Could they be giving erratic voltage readings?
    North London
    Quote Originally Posted by John C S View Post
    I have tried a different bulb and holder with no joy
    May 2007
    Quote Originally Posted by okanac View Post
    Fair do's Bud, I just know how annoying it is when the obvious is overlooked.
    Hello and to the site BTW
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  3. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
  4. massivly erratic 3.0l
    By Adamdavi3s in forum Engine & Drivetrain
    Last Post: 7th August 2008, 16:09
  5. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
