Hi guys
New fault this morning when i rotate the temp dial on my heaters through to full heat there is no heat just one temperature (cold).
Is it likely to be the heater switches or something else.
John
Hi guys
John
Could be a fuse perhaps?
update
In the passenger footwell near the centre console there is a small black motor with red rods it is barely moving about 0.5 cm is this normal
Anybody know the vx part number
John
Is there enough coolant in the engine? The first thing to stop working is the heater if coolant level drops.
it sounds like it's a servo motor fault on the airvane that blends the heated air...
My heater has died this morning also.
Blower will only work on No.4,which will give heat, otherwise nothing and it is cold.
Should have searched first![]()
