Results 1 to 10 of 11
Thread: Buying a welding set - advice please
    Inverurie
    confused Buying a welding set - advice please
    Hi folks,
    I've got myself a little kitcar project and it is need of some welding in places. So having passed a basic welding course at Uni and having read somewhere that Inverter Welders are better then your standard ARC or MIG welders (I'll happily go with someone in the knowledge here though so don't read that as me having decided in an Inverter Welder ) Can you have a look at a couple of these please? I am just after a one that will do some small jobs rather then patch up the Forth Road bridge if you catch my drift.
    Inverter Welding set 1
    Inverter Welding set 2
    Many thanks,
    Andy
    the question i have to ask is what do you really WANT to weld??.. if it's just car chassis stuff and it's old metal then an inverter ( DC scratch TIG set) will just hate it..they like good clean new metal, and not too thick either at that power rating..
    Arc is good on clean or rusty metal, but harsh and burns through very easily..it's main advantage over inverters and MIG is having no need for a sheilding gas supply..
    if it's convinience and ease you're looking for, then buy a fan cooled MIG set..as powerful as an arc set, but as controlable as an inverter....Hence why they are so popular..gasless one's are 'okay' and basically a continual arc setup..with the sheilding gas flux being part of the core of the wire..
    Having been trained in welding since my early teens i'd have to advise you to go the MIG route...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would have to agree, gas shield MIG has to be the way forward.
    Get yourself a properly regulator and an old style pub CO2 bottle. It will save you a fortune as the small CO2 cylinders don't last long and will work out far more expensive.
    The first thing to make, is a trolley so you can wheel the set around with the bottle attached. You will find it invaluable, and is an easy practice for you with the new set before you attack the car.
    Nov 2005
    Edinburgh
    I suggest you have a look at some of the information on this site:
    http://www.mig-welding.co.uk/
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have done many cars up in the past that have needed lots of welding and I always used a Mig welder and always had good results.
    Go for a named one ie Sip, Clarke which I had, make sure it has a non live torch otherwise you will be arking everytime your torch touches metal, and idealy no lower than 130amp and Turbo cooled as that lets you weld for longer. My mig uses gas and the argo/co2 gives a really nice neat weld, I cant comment for the No Gas models as I have never used one and also take your time as you will get a better finish.
    wales
    i have a mig m8 and use on cars all the time go mig route ps.i also use arc and gas welding
    Inverurie
    He he, can't beat experience over random stuff you read can you
    Ok, I'll look at some turbo MIG sets at 130A or above.
    Much appreciated.
    Andy
    ps it is a part built one of these I've got Clicky
    wales
    anything over 130amp think you need to use a higher ampage socket (cooker) but i use 130 on normal sockets have a look into it before you buy just incase if thats any help
    May 2007
    WINSFORD
    No the electric is fine, my mig is a Clarke 150 turbo and its fine and I have a friend who has a garage type mig thats a 180 turbo and normal plug/ electric again. Avoid 3 phase as its a totaly different electric supply and is commercial use only
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    my old man has an electric MIG kit that i brought him about 10 yr's ago CLARKE iirc and it's great...even i can use it
    Midlands Mod Shop - NFFC.
  1. Mig Welding - Advice please
    By alcutler in forum Engine & Drivetrain
    Last Post: 30th April 2012, 13:40
  2. Buying advice 08 sri 150 what should i look out for
    By duncmill in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2011, 19:58
  3. buying advice
    By astra_baz in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 04:46
  4. 2.0T buying advice
    By pricey in forum Petrol Engine related
    Last Post: 14th August 2007, 15:20
  5. Advice on buying new car
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2006, 15:13
