View Poll Results: what oil do you use
Voters
92. You may not vote on this poll
  • 5w-30 fully synthetic
    61 66.30%
  • 5w-30 semi
    10 10.87%
  • other fully
    10 10.87%
  • other semi
    11 11.96%
Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
Thread: what oil do you use
  1. #41
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by macdad View Post
    This question often crops up ,and the answer is still the same.
    If your car in on vx eco flex service sched ,then the recomendation is to use 5w 30 fully synth which is supposed to last for 30 ,000 miles approx,and the service indicator will react accordingly,its permissable to also use 10w 40 semi synth if your on a shoter time span/mileage service sched...change at 10,000 0r 1 year which ever comes first,this applies to the dti engines..however the cdti engine is on a different service sched,afaik you must use 5w 30 fully synth @ 20,000mls intervals.
    Vx have put the 10w 40 semi in mine for the annual service
  2. #42
    Regular Member mattolly86's Avatar
    oxfordshire
    what engine you got?
  3. #43
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Quote Originally Posted by Ian S100 View Post
    They did the same for me, got a call today after contacting GM to ask which oil they should have used. garage said it "probably" used the correct oil, but there "must" have been a clerical error on my invoice, and asked me to go back tomorrow for free oil & filter change. Stealers, dont you just love em! Ah well, a fortnight of 1w/40 wont hurt, I will think of it as a flush!
  4. #44
    Mar 2007
    Beaconsfield, Bucks
    Mine did the same to me, they noted it down as Shell Helix. I complained and they replaced it with 5W30 fully synth (I watched them too! Bet they regret putting a window from the sales area to the service area in) and I got a free 5l tub of it too to say sorry. Then again the service was probably overpriced anyway!
  5. #45
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by Sean-2.2Direct View Post
    Vaux put in 10 w 40 in my 2.2 direct
    same here in my cdti 120, changed every 10k
  6. #46
    Oct 2007
    south wales
    Quote Originally Posted by ditchp View Post
    Check what it says in the service manual, if you are on the ecoflex service schedule it will specify 5w/30. If you take it to a stealer for a service then they should follow the service schedule. 10w/40 ( as long as it is the right spec ) will not neccesarily do any damage over 10k depending how its driven.
    My complaint is that I paid for a service for my 1.8 vvt, and they used the wrong oil as specified by GM. God knows what their 10w-40 bulk oil is like, thats why I always change it myself unless I need a stamp as I did in this case. I will still change it in 6 months though..........
  7. #47
    Regular Member old cruiser's Avatar
    slough
    Was using 5w30, now switched to 10W40 as the car seem to be using far too much oil for my liking, so just experimenting at the moment just to see consumption difference, which at the moment seems better with it being a thicker oil and also bearing in mind there was an issue with some 2.2 engines somewhere between 2002 and 2004 I believe; having 'Not to specification piston rings fitted at factory' and hence high oil consumption, ****** cars who 'd have 'em!!
    Cheers Pete
  8. #48
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    GM 10W40 semi - changed every 15,000 km (5 months) - as advised in the service manual
  9. #49
    Devon
    101 Post(s)
    Vehicle : insignia
    Trim : irmscher
    What oil should i be using in mine ? 2.0dti 140 on clocks,last time i rang stealers for a quote they said i should use semi not sure what rating tho
