Thread: Carb Cleaner to clean Injector Plugs??
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Default Carb Cleaner to clean Injector Plugs??
    Is it wise to spray 'Carb Cleaner into the Injector Plugs so that I can give them a good de-corrosion clean?
    Jul 2006
    You can do... Much safer and better just to use a decent fuel additive like Millers Diesel Sport 4 or change your fuel to V Power Diesel..
    Jan 2008
    South Wales
    Quote Originally Posted by parapaul View Post
    No VPower diesel around here so iv got standard Shell and a double dose of Millers Diesel Sport 4 at the moment and have been using for about 4 days. I was having bad trouble with juddering and the spanner light flicking on and off, so I cleaned the EGR VALVE and BOOST SENSOR then the injector plugs the other day. It has been fine until last night, so I just wanted to know was the safest and best way to clean the injector plug connections so to clear all the corrosion and dust from within?!
    Belfast
    Electrical contact cleaner would be better than carb cleaner. No residue. Once plugged in I'd stick a bit of WD40 over them too, should keep water away.
    parapaul, how does Miller's clean the connections to the loom on the injectors?
    Jan 2008
    South Wales
    Quote Originally Posted by _ZS_ View Post
    Chees ZS coz thats exactly what I was thinking! Electrical contact cleaner it is then, off to the shop i pop!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Paul was prob thinking about cleaning the injectors, and not concentrating too much on the word 'connector' - he's probably a bit tired.
    Belfast
    You know something we don't Ste?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No, just that he may have finished work at 2pm.
    M1 south was a bit busy this morning at J24 - J23A. Lots of emergency vehicles around at about 7am
  1. Replies: 1
    Last Post: 15th September 2012, 21:13
  2. carb cleaner
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2011, 00:18
  3. Carb cleaner
    By nokiaman1978 in forum Engine & Drivetrain
    Last Post: 7th August 2011, 19:53
  4. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  5. Replies: 7
    Last Post: 2nd July 2009, 17:51
carb cleaner on diesel injectors
vectra c cleaning engine electrical connectors
how to clean imjector plug diesel
how to clean diesel injector electrical connector
carburettor cleaner diesel injector
carb cleaner for injwctors
