Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: idling rough
    Belfast
    Unhappy idling rough
    Hi folks
    tonight i have had another problem with my vectra cdti 120, my battery still hasn't been changed yet but thats gonna happen tomorrow as its very weak, i had a mechanic friend look at it and thats what his diagnostics said.......
    anyways my car started to idle rought tonight around the 800 -1000rpm and i have noticed it being a little down on power does anybody have any ideas what this could be cheers
    brian
    Regular Member benny's Avatar
    Feb 2006
    dudley
    why is your battery flat ?.......
    if the altonator isnt charging the engine will not run correctly
    check the plugs on the injectors for corostion and corect fitting ...
    Belfast
    my mechanic friend checked it and said it was only puttin out 13v which is shocking
    i never thought off that, im gettin the new battery tomorrow but could it be the EGR valve also??
    brian
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    could be a faulty alternator ask at your dealer to check if it comes within the batch of faulty ones, as to the rough idle it could be the swirl actuator bar fell off, take off the engine cover and look in-between cam covers to see if the shaped bar has come off!(common fault ) if so search thread's for ''how to fix inlet manifold for a quid'' best of luck!
    Regular Member mattolly86's Avatar
    oxfordshire
    vx have just fitted a new alternator on mine free of charge as it was deemed a faulty part when fitted recalled most of the range maybe worth checking as for rough idling egr shouldnt effect it that much try unpluging it just to test
    Belfast
    well folks i put the new battery in today and the car has a vibration when sittin around 1k rpm?? i thought it could be dodgy fuel because it takes abit off effort now to start and it doesnt sound to good when doing it either!!
    whats yrs did the faulty alternator lye between
    brian
    oxfordshire
    i dunno mines a 54plate hope it helps
    Belfast
    happy days ill give them a buzz tomorrow and enquire
    brian
    Belfast
    warranty ran out in july and to top it all off its not the alternator its the fly wheel, does anybody know a good place to get parts from either in the uk or northern ireland!
    brian
    oxfordshire
    wow a fault with the flywheel if your cars got full vx service history talk to them about good will a flywheel cant be tampered with unless youve had your engine out or clutch done so if its faulty its the parts fault get vx to pay atleast some of the cost
  1. 3.2 Veccy C rough Idling
    By maleko in forum Engine & Drivetrain
    Last Post: 4th June 2012, 08:32
  2. 3.2 Veccy C rough Idling
    By maleko in forum Vectra C / Signum Car Chat
  3. siggy 1.9 cdti rough idling
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 11:47
  4. Rough Idling
    By iainm in forum Engine & Drivetrain
    Last Post: 12th August 2009, 22:51
  5. 2.2 idling
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:00
