Thread: V.noticeable Rumble/vibr From Front At 70+mph
    glasgow
    Default V.noticeable Rumble/vibr From Front At 70+mph
    Vectra 1.9cdti 150. Drives Fine About Town But As Soon As Im On Motorway At About 70mph There Are Very Noticeable Vibrations Felt Through The Steering. Not Much Idea What It Could Be, Wheel Balance Done Not So Long Ago So Im A Bit Stuck....any Suggestions ? Cheers
    Jul 2006
    The Vectra C is really sensitive to badly balanced wheels - I'd take it somewhere else, and ask them to rebalance the front wheels using 'fine' settings. This balances them to the nearest gram, rather than the nearest 5g.
    Start with the cheap options first
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by parapaul View Post
    .......... the balancing you will need is call precsion wheel balance
    Chester
    The place I bought my tyres from for over ten years couldn't balance the wheels on my last Vec. Luckily a garage was recommended on here which is reasonably local and I asked them to balance them just as Paul suggested.
    Perfect afterwards and the only place I will go to now.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    I had this sort of problem (mine was more the steering wheel just penduluming subtly from side to side) at motorway speeds.
    Had 2 new front tyres and a four wheel alignment and it sorted it.
    Belfast
    Some cheaper tyres can go out of shape at speed, making them impossible to balance. I had a pair of Hankooks in the past that drove me crazy for going out of balance. End up I dumped them with 6mm tread left, put on a pair of Bridgestones and no problems after that at all.
  1. Rumble and clunking
    By Gazza36 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th July 2012, 20:28
  2. Knocking from front end not loud but noticeable
    By tomo41 in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2011, 13:58
  3. First noticeable Modís have begun
    By Keefyb007 in forum Styling
    Last Post: 19th November 2010, 13:15
  4. Rumble when changing up 1st - 2nd
    By Hobo in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2010, 21:30
  5. front end rumble
    By prof1908 in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2009, 13:38
