Thread: Car undrivable. Limp home mode?
    Brighton
    Angry Car undrivable. Limp home mode?
    I have a 1.9 CDTI 150 PS Vectra C 2004. The car started juddering, the car\spanner icon came on intermittently. The icon is now on all the time and the car has no performance and sounds like a bag of nails. The exhaust emision light is on as well. HELP please!!!
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    sounds exactly as mine did when i had injector trouble...
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Quote Originally Posted by foggy View Post
    The EGR VALVE could be blocked full of soot m8, check out this thread coz this is what could b causing the problem:
    http://forum.vectra-c.com/showthread.php?t=45867
    Also check ur injector plugs, they could b dirty and causing the juddering like they did in mine, this thread will show u what to look for:
    http://forum.vectra-c.com/showthread.php?t=59299
    Regular Member mattolly86's Avatar
    oxfordshire
    i had same symptoms with mine when i managed to get a crack in my intercooler
    Brighton
    Many thanks, all sorted. Was the No 3 injector that had dirty contacts and when cleaned up worked as normal.
    Again many thanks
    Jan 2008
    South Wales
    Again many thanks
    Just out of curiosity what did u clean them with? I used 'Electrical Contact Cleaner' and a couple of ear buds, its 80% better but not gone completely!
    Brighton
    First time back at the forum since the last post. The cleaning was not that successful, about the same as yours.. What I've now done is put a cable tie around the body of the injector and the connector and pulled it up, but not to tight to damage anything. This works. I think it is the connector on the loom that is at fault, contacts damaged, and, although the cable tie solution works, am going to change it. Will let you know how this gets on.
    Jan 2008
    South Wales
    Im trying to find out how to get hold of a 'modified injector plug wiring harness kit', coz apparently this will help fix the problem!
    Does any1 know if a 'modified injector plug harness' has been fitted to the Facelift model, coz if so ill find a breakers that has a Veccy then take the harness off?!
  1. limp home mode
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 09:12
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. limp home mode
    By fig in forum Engine & Drivetrain
    Last Post: 20th January 2010, 23:18
  4. CR2 going into limp home mode
    By plasma in forum Diesel Engine related
    Last Post: 17th April 2006, 20:45
