Results 1 to 3 of 3
Thread: Drivers door window switch connector
    Newcastle
    Question Drivers door window switch connector
    Hi,
    I'm trying to remove the window switch from the drivers door, and have easily prized it out. Problem is that I can't get the wiring connector off the switch. Anyone know how to do this please, is is a straight pull, or is there a clip or something that holds it in place?
    thanks
    Neil.
    Regular Member Robbie69's Avatar
    there is a clip, it's difficult to explain how it works though. There is a tab, push it down and you should see how it works. Not much help but you'll see why it's hard to explain once you've worked it out.
    Mileage : 000
    A bit like the rubic cube then. Sorry I am not much help though, buthope you out how it comes off.
  1. drivers window switch
    Last Post: 27th December 2012, 14:01
  2. How do u unplug Door switch Connector ???
    By Dal5band in forum Bodywork & Interior
    Last Post: 28th March 2012, 23:19
  3. Drivers door window switch problem
    By armbuster in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2009, 14:54
vectra c window switch removal
vectra c estate drivers door swit h elite
vectra c how to get window swtich out
vectra c window connector
vauxhall vectra door switch removal
Vauxhall meriva window switch removal
vauxhall insignia removal of drivers door window switch
how to unplug a vectra window switch www.vectra-c.com
how to remove vectra window switch
how to remove vectra window switch connector
removing vectra c door switch
https:www.vectra-c.comforumshowthread.php62244-Drivers-door-window-switch-connector
vauxhall vectra window switch
how to unplug from drivers door multi switch 2008 vectra
vectra c drivers windows switch removal
insignia how to remove door wi.comdow switch
