Thread: Steering Fluid.....
    cr26pr
    Default Steering Fluid.....
    Just went to check the level on the power steering fluid as the light keeps coming up and disengaging the power steering...(that another story)
    How on earth am I supposed to check and top-up the fluid!
    If Iím looking in the right place it's under the headlight?
    Anyone else tried to check theirs? How did you do it?
    Regular Member cpt slow's Avatar
    In a house
    Thats the correct place , but im in the same siutation as you ! How on earth do you check and top it up ! Someone will be allong soon im sure to rectify this .
    This PDF should help guys (two documents combined into one).
    To get into the tank to check levels etc. involves removing a front panel! All the info is there. It's normally meant to all be maintenance free, so you want to be finding out why you're losing fluid in the first place!
    BTW - unless you've got a Signum with the 1.8 engine, you'll have EHPS, not Compact EHPS.
    HTH
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    often wondered how you get to the power steering reservoir,what a lot of messing about,mines ok I don't think I'll bother till it goes wrong!!!
    another case of design over useage(theres a gap we'll put it there)
    reminds me of the vauxhall ads when Griff Rhys Jones did then with the sardine can!!!!
    Jan 2006
    Skynet HQ EMEC#5
    That looks a bit involved. Glad mine's easier to get to, over the back between engine and bulkhead. Sits on top of steering rack, it is the 1.8 engine.
    In a house
    Very interesting that read, what would happen if you ran the car with no fliud in the resoviour . What damage would this do ?
    It'd wreck the pump in no time..Then mucho dosho..
  1. Power steering fluid
    By Friel in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2011, 23:29
  2. Power steering fluid
    By dittohead in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 12:50
  3. power steering fluid
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2010, 09:46
  4. Power steering fluid
    By steven_armit in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2008, 22:24
  5. Power steering fluid.
    By WOODY1972 in forum Engine & Drivetrain
    Last Post: 20th April 2006, 08:21
