Results 1 to 10 of 18
Thread: headlight bulb removal
    liverpool
    confused headlight bulb removal
    sorry if this has been asked, but how do you remove the dipped headlight bulbs. I cant see a circlip and i've read that they twist out?? is this true? can any one shine some more light on this please. my drivers side bub has gone. I can get my hand between the airbox and the light unit but simply don't know how to remove the bulb.
    Cheers, Andy
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    hi mate it just pulls out on mine but it is a facelift model but i think they are the same
    liverpool
    They just pull straight out? Back towards the air box? not twisting or circlips? I'll give ita go now.
    Regular Member Lump's Avatar
    coventry
    i am having the same problem on the drivers side, there are two small detents which hold the bulb in, the bulb wont pull over them to get them out
    Belfast
    Facelift dip bulbs just pull straight out. NO twisting (you'll **** it up if you start twisting)
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Quote Originally Posted by _ZS_ View Post
    I agree , did mine this morning ( Osram nigthbreakes installed )just give it a yank..........phnar phnar........
    Belfast
    Oh, did you pull your wire, sir? Did you? Then insert your bulb in the hole? In it? Oooh! Suits you sir!
    *cough* I'll go get my coat.
    Oct 2007
    south wales
    keep your hands off my shiny big bulb.............
    coventry
    nope mine wont come out, the two detent need to be pushed away to allow the bulb to come out, will have to take out the air box
    liverpool
    on the non-facelift model - the bulbs twist out. The drivers side twists anti clockwise. as you look from the rear of the car. Simply grab the black thing (sorry i don't know hat its called) and twist it. The bulb and mount will then become free and there should be enough play in the wires to bring bulb level with the top of your air box. This should give you more room to changethe bulbs over.
    There are a few diagrams in the owners manual.
    Thanks for the replies. I've just changed mine now.
  1. headlight bulb
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2013, 22:18
  2. Headlight bulb
    By Dazzy2006 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2010, 22:03
  3. headlight bulb upgrade
    By victorM in forum Bodywork & Interior
    Last Post: 28th September 2009, 07:53
  4. Front fog bulb removal
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 02:58
  5. Headlight Bulb
    By Avenged in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2009, 02:05
insignia headlight bulb removal
Remove drivers side headlamp from vectra c
Why wont my vectra c headlight bulb pull out
remove vauxhall insignia headlight
remove drivers side headlamp on vectra c facelift
how to remove a vauxhall insignia headlight
remove vectra headlight
vectra c headlight bulb upgrade
how do i get the heaadlight bulb out of mt 2006 vectra
vectra c driver side headlight bulb
