Results 1 to 10 of 11
Thread: Rear power for small active sub?
    Belfast
    Default Rear power for small active sub?
    Looking at one of these:
    http://www.justkenwood.co.uk/speakers01/kscsw10.asp
    Thinking if I could tap into the power in the boot somewhere, it would save me having to pull power cables through from the front. Estates have a 10A power connector in the boot - is it possible to retrofit that on the hatch and use that for running the sub? I only need 8A to run the sub.
    Suggestions?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    No dont, you need a direct link to the battery
    Belfast
    For 10A? Really? Is that NEED or PREFERRED?
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Quote Originally Posted by _ZS_ View Post
    I would say need - expensive mistake if it all goes wrong.
    Jul 2006
    Just look at the size of the power cables in the boot looms compared to even the smallest gauge power cable you would use for an amp (about 8AWG) - they're tiny.
    It's not that big a job, especially if you're not trying to run RCA cables as well. I'd say it would probably only take an hour tops.
    Regular Member Hs2300's Avatar
    yorkshire
    Surely the 30amp connection in the rear module would do?
    Belfast
    My point exactly, Hs2300. It's only a little 100W sub - I'm not entering any soundoffs.
    Jul 2006
    Northampton
    Trim : Sri
    No you cant as the sub will be pulling more current than the connection is supposed to which could, in an extreme event but possible, cause a fire. you need to run a wire directly to your battery as the battery will be able to supply the amp with enough current and the wiring will be able to handle it
    Belfast
    How can it? 10A outlet, 10A fuse on the sub, 8A current draw. Where's the extra current draw going to come from?
    I'm not trying to be difficult here, I'm just not seeing any reason why I would need to pull huge power cables from the battery for a small sub like that.
    Jul 2006
    Northampton
    Trim : Sri
    You dont need a huge power cable, i would assume a 12awg cable would be enough. its all about voltage, current and resistance. I dont know the exact details but i know enough not to try wire it up to any outlet within the car only directly with the battery, you also have to consider the other components being run from the connection, running it direct from the battery offer the least resistance, most power and is solely being used by the sub on that cable.
  1. rear 12v power supply???
    By big rich in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 22:38
  2. Power Steering Question (Vectra 2.0 Active DTI)
    By Shadrack in forum Vectra C / Signum Troubleshooting
    Last Post: 16th December 2009, 22:38
  3. Anybody seen ........ not been Active for a while
    By WeDesign in forum The 'Off Topic' room
    Last Post: 22nd June 2009, 15:13
  4. rear 12v power point
    By Dippy-Vx-line Red in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2008, 21:25
