Thread: Hard Wire PDA
    edmonton
    Default Hard Wire PDA
    At present my PDA/SATNAV is connected to the cig lighter socket. This is far from ideal as it is not a permanent live.
    The PDA sits on the far right, so can anyone advise on how to hard wire from this position. I have found a posting mentioning the headlight switch as a possible solution, but I have no idea how to gain access to the back of the switch.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    The switch can be removed by pressing in the dial and twisting it (to the right IIRC) and it can then be pulled out.
    One of the wires is a permanent live and I think its noted in the thread you may have read.
    edmonton
    Thanks for info. Will check that out. Do the PDA wires need soldering
    To the switch ?
    Regular Member Damian's Avatar
    Market Drayton
    Quote Originally Posted by samuel View Post
    To the switch ?
    You can't just chop the plug off your PDA as it containes a fuse, and your PDA won't run off the full 12v and you will fry it.
    The two options you have is to buy a hard wire Brodit mount for example, or what I did was to put a 12v multi adapter behind the dash, chop the plug off that and hardwire that into the permanet live / switched feed, then plug my lead off my PDA in to the multi adapter.
    edmonton
    thanks Damian , I have a multi adaptor
    and will go for that option
  1. What wire do I cut lol
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2012, 09:01
  2. Snooper hard wire help
    By Stue123 in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2011, 07:53
  3. Hard Wire Sat Nav / PDA - questions. . .
    By Achilles2k in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2011, 00:04
  4. Hard wire a Bluetooth Mirror
    By Exclusive BV in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 16:35
  5. Hard Wire my Ipod in
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2008, 10:53
