Results 1 to 10 of 18
Thread: AFL light out
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 103000
    Question AFL light out
    HELP
    When you have a AFL bulb go (hid) would it just not work
    Or like mine start to flicker just when turning a corner
    Heres what happened
    I turned right at a set of traffic lights with the drivers side, dip beam flickering then it was working fine going straight ahead
    Then i turned left & it flicked again & went out
    PS: Does any one no the part number & will i be-able to change it myself
    Cheers for any advice
    PPS i have network Q cover still on the Vec but i dont think that covers bulbs
    Regular Member Stu14t's Avatar
    Perth, Scotland
    I think there was a issue with some units letting in water in. Should be replaced under warranty.
    Do you get the AFL warning light on ? and are the turn lights working?
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 103000
    Hi Stu
    AFL warning light is not on
    just the bulb warning light on the dash & central display
    all lights work apart from the drivers side dip beam
    i keep popping out to see if it will come back on lol
    ps both dip beam lights still turn fine
    Perth, Scotland
    Sorry, I wasn't clear, I meant the halogen turn lights. The ones that come on when you turn the wheel tight and put the indicators on.
    If one of them goes the fog light on the same side comes on.
    It's definitely the main xenon bulb? If it is you should get that replaced under warranty. HID Xenon's, as a rule, should last the life of the car.
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 103000
    yep halogen turn lights come on
    i thought my driver side front fog light would come on, with the drivers side dip beam out, but the fog light didn't come on
    My main warranty has just ended but i still have the Network Q warranty untill june 2009 (i just hope that will cover it
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 103000
    I priced a hid bulb up in town £85 + vat
    They said it was a D1S
    Perth, Scotland
    It's a bit of a mission to change the bulbs. I changed mine to 6000K bulbs. I lined them up on the garage door first and drew a line where the beam pattern was. You then need a willing helper to assist in taking the bumper off and then you have to take the entire headlight unit out. You can then undo the little door at the back 2 X torx T20
    The bulbs are D1S not D2S as with the pre-facelift and you can get them off ebay for about £30
    Perth, Scotland
    There is one Here for a £25 if your quick +
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 103000
    Cheers Stu
    I'll let you know how i get on with the dealers
    Thanks for the tips on how to fit (hope i dont need them)
    Did you have to disconnect the battery to fit them (I've read the warnings)
    ps i've got my eye on it Cheers
    Perth, Scotland
    Oh yes the ballasts make 18000 - 25000 volts to strike the arc so watch out
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
