Thread: suspension upgrade
    Jul 2009
    leicester
    Angry suspension upgrade
    anyone help? I have an 08 vectra 1.9 cdti, the suspension is soft, making it bounce around corners, my kids get sicker than a sailor in a storm. Plus I tow a caravan.
    I want to stiffen up the rear suspension, for handling and taking the weight of the caravan. I know there are kits to lower it completly, but thtas not an option as it is a company car and it won't help with towing.
    Regular Member kns's Avatar
    Northampton
    Put some SRI Springs on the Rear £191 for two at the staelears(mind you they do pull your pants down at this price)
    Or you could buy two of me for £40 collected
    Forum Moderator FIL 4822's Avatar
    Central England
    7 Post(s)
    Vehicle : Vectra VXR, VW Tiguan R-line Tech, Vivaro.
    Trim : Nav
    Engine : Various
    Year : 1 A.D
    Mileage : Rising
    If you load the caravan correctly, you shouldn't need to uprate the rear suspension.
    I made sure that i had between 75 to 100 lb's weight on the towball.
    Try www.towsure.com/category/6781-Noseweight_Gauges
    It WILL make a big difference to your towing.
    Hope this helps.
    Regular Member Graham's Avatar
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    I thought Vectras had a max towball weight of 60
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quote Originally Posted by Graham View Post
    Sorry just checked my handbook and it says 78 lbs
    Regular Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Quote Originally Posted by wraggs View Post
    If You have a look at my posts here, I have found a producer of springs that make reinforced rear for the Estate, who is not lowering, only thicker/stiffer springs. Have just changed all springs / absorbers / etc on my Vectra, and are very happy with the suspension in rear, perfect for caravan. I changed to some autolevelling shock absorbers from KYB, who also do a very good job, especially with heavy load.
    I have a issue with to soft shock absorbers in front, but waiting from answers from KYB about this.
    Youll find links for UK distributors in the above mentioned tread.
    Best of luck
  1. suspension. anything to upgrade?
    By wullie-t27 in forum Handling & Braking
    Last Post: 5th December 2012, 07:56
  2. 3.2 V6 GSi - suspension upgrade?
    By buster mcthunderstic in forum Handling & Braking
    Last Post: 13th January 2012, 23:28
  3. Suspension upgrade
    By Tinks in forum Handling & Braking
    Last Post: 10th January 2012, 20:35
  4. LX Suspension upgrade
    By Birchy63 in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2010, 13:42
  5. Suspension (down?)upgrade
    By mickeyc in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2007, 11:38
