Thread: Vectra C Estate Stuck Tailgate Problem solved
    edmonton
    Smile Vectra C Estate Stuck Tailgate Problem solved
    Problem is the micro switch becoming stuck. To fix remove back panel ( 2 plastic pins and screw from inside the grab handle)
    Undo the 2 nuts holding the release switch in place disconnect the cable, and take out the unit.
    Remove protective cover and clean grease from around the micro switch.I managed to free the switch by gently pressing it and when freed pushing on and off till movement ok.
    I believe there is a spray that is available to clean and protect electrical parts that may prevent a re occurance of the problem, not sure what it's called though.
    Surrey
    Electrical contact cleaner.
    Surrey
    edmonton
    Thanks for info.
    Regular Member Karl's Avatar
    Sunderland
    I used the less sophisticated fix, I bashed the boot several times to "unstick" the switch, did dent the boot slightly though, lol
    edmonton
    you know I did try the less subtle approach, unfortuneately I now have the Vauxhall Badge imprinted on the palm of my hand.!!
    Maida Vale
    Quote Originally Posted by samuel View Post
    Similar to the black-leather-coated-SS-guy in Raiders of the Lost Ark?
    Yep, seems to be 'common' on the Signum with the estate being the same sort of set up.
    edmonton
    Quote Originally Posted by Thomas1 View Post
    yep, that's the one.
    Trouble is that when I shake hands people feel the car I drive!!
  1. Estate Bootlid/Tailgate problem
    By Jazamed in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd January 2012, 20:37
  2. Estate tailgate problem.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 18:33
  3. Vectra C estate tailgate not shutting
    By spook123_uk in forum Bodywork & Interior
    Last Post: 13th January 2010, 14:41
  4. Vectra Estate power tailgate problem
    By Snizzers in forum Bodywork & Interior
    Last Post: 3rd June 2009, 23:03
tailgate castle micro switch vectra c
vectra estate power tailgate
vectra c estate trunk fix
