Results 1 to 10 of 29
Thread: 57 reg Vectra SRI - Knocking in boot!!
    WAKEFIELD
    Default 57 reg Vectra SRI - Knocking in boot!!
    Hi, i've just registered so i'm not sure if this is the right place to ask this.
    Basically i have bought a 2007 cdti SRI (150) and there is a knocking noise coming from the boot/rear area. Its getting worse, so not only making a noise over a bump it now continually knocks.
    Its not a mechanical noise and sounds like the parcel shelf or rear seats but i have taken the parcel shelf off and unlocked the seats etc to see if it stops but it doesn't!!! I've also checked the spare wheel locking which all seems fine.
    I just wondered if this is a common fault and has anyone out there experienced this?
    Regular Member monkeytwo's Avatar
    Camberley, Surrey
    I had a similar problem on mine.
    As you say its sounds like the parcel shelf is loose but its not!! I found that on mine it was the boot sill that runs on top of the bumper, it was pushed all the way down and the knocking was coming from the boot lock.
    I pulled the rubber strip up slightly and the noise disappeared, might be worth a try?????
    Surrey
    Is it the boot lock?
    WAKEFIELD
    Cheers for the advice, i'll have a look at it when i finish work and see if it relates to what you both say.
    I know it will be something small but its really annoying!!
    Stepper19
    Surrey
    Les us know how you get on.
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Mine did that, drove me batty! I stripped out all the panels in the boot to trace it. Turned out to be the boot lid itself on the catch. You can adjust this using the bump stops on either side of the boot lid. Might be worth checking that!
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Quote Originally Posted by steve1975l View Post
    Odds on it will be this. Had this on mine and my dads, drove me facking insane!!!
    Surrey
    Mine has been doing it since Monday now too and is something to do with the boot as it started after I emptied it last weekend. I will look at it tomorrow.
    WAKEFIELD
    Thanks for the advice, hopefully i can sort it tomorrow. I won't have to turn the radio so high to drown it out!!
    On a different subject........i don't have much experience of increasing a cars performance through chips or kits etc but what is there out there that is realitively low cost which will increase the bhp and performance of my car??? SRI CDTI 150bhp. How easy/costly are they to fit as well??
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    you sure it's not this??
  1. knocking on vectra
    By briggsy in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 09:32
  2. knocking noise on my vectra
    By vectranath in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2009, 21:59
lumping noise coming from boot cdti sri 2006
