Results 1 to 3 of 3
Thread: cleaned boost sensor and still shows over boost
    chesterfield
    Default cleaned boost sensor and still shows over boost
    i cleaned boost sensor last night on the 2.2dci 52reg
    it was preety clean with no gunk at all?
    after cleaning i took a run and performance still slightly down and boosting when ever it feels
    diagnosis still comes up over boosting when light comes back on the dash
    only thing i noticed was a slight bubble on the yellow sensor element inside the boost sensor
    is there suppose to be a slight bubble ?
    the bubble is on the yellow element closest to the black flat thing in the middle
    i would buy a new one tomorrow if i wnew 100% it was this at fault but at £65.00 from local dealers it would be nice to know if there is anything else that could cause over boost before buying
    all pipes ok double checked
    cheers all
    overboosting..
    dirty or damaged boost sensor
    stuck wastegate on turbo/faulty wastegate actuator
    split or perished vacumn lines leading to turbo.
    chesterfield
    overboosting..
    cheers again
    i think i know where the wastegate is>>> (behind turbo with a threaded bar and nut on it for adjustment)
    i will look at this to see if anything visual wrong with it
    if there is only the 3 things that could cause overboost then it might be worth just buying a new actuator and pipes and sensor
    cheers
  1. One cleaned Boost Sensor......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 20th August 2012, 00:22
  2. Cleaned boost sensor
    By 130786howe in forum General Chat
    Last Post: 8th July 2012, 16:22
  3. please help, eml still onl, cleaned boost sensor and egr
    By J P S in forum Engine & Drivetrain
    Last Post: 31st May 2012, 12:25
  4. Just cleaned my boost sensor
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2011, 19:43
  5. Just cleaned my egr and boost sensor !!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 17:32
