Results 1 to 3 of 3
Thread: Clutch/Gearbox Noise
    Southport
    Default Clutch/Gearbox Noise
    Hi all, just wondering if anyone can diagnose an annoying noise for me, its coming from the Clutch/Gearbox area and is only noisey when im slowing down in any gear. It sounds like a worn wheel bearing noise but from the gearbox area and only when slowing down but if i press the clutch pedal whilst moving or accelerate it goes completely away. It started doing this 2 weeks ago and hasnt got any better or worse. The noise is not there at all when the car is standing still either with the clutch pressed or without.
    My car is a Petrol 2003 1.8 SRi manual with 89k on the clock. A local garage has suggested checking or changing the gearbox oil to see if it will sort it but i dont know which direction to go with it.
    Any help would be much appreciated thanks in advance.
    Cheers Scott
    it's internal waer inth egearbox causing backlash which is making the 'howl' when you decellrate as the geartrain thrust is applied to the opposite side of the gearset on the overrun...
    best case scenario, change the gearbox oil..worstcase scenario it will need new bearings/gears in the box ..
    Southport
    Thanks for the info, i have booked it in for the oil. I need to use the car daily do you think it will be ok to still use it.
    Cheers Scott
  1. Clutch / Gearbox noise / rattle CDTi 150
    By Paul_B in forum Engine & Drivetrain
    Last Post: 1st March 2013, 17:21
  2. Vectra C 2.2 DTI Clutch/Gearbox noise problems
    By Gramoz in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2012, 14:13
  3. gearbox and clutch
    By vectra craig in forum Engine & Drivetrain
    Last Post: 13th June 2012, 19:50
  4. Clutch?? Gearbox??
    By wingz123 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th March 2011, 10:47
  5. New gearbox and clutch
    By 2.2direct-sri in forum Engine & Drivetrain
    Last Post: 21st July 2009, 13:52
