Results 1 to 10 of 11
Thread: engine woes 2.0 DTi
    Nov 2007
    Chesterfield
    Default engine woes 2.0 DTi
    Hi all, got a vectra on a 52 plate, and its covered 157k however, last week, it developed a kind of top end rattle i went to a local garage and the guy told me not to worry given the mileage. had it serviced on saturday and also put injector cleaner in it, the guy who serviced it said basically the same as the local garage chappy........ this morning i had just pulled out of a junction and selected 2nd gear and to describe what happened was like it jumped out of gear (but it didnt) and it died. tried to start it it was like a dying battery and a kind of klonk at certain times as the engine turned over. it flat refused to start i havent had the oil light on at any time and thinking about the noise it reminded me of the noise that the ford pinto engine used to make when the camshaft went. i was also told that the 2.0 DTi CANNOT be rebiult ...... any ideas please / prices many thanks
    Regular Member garvey's Avatar
    Co Durham
    welcome to my world mine did it at 159,000 first time then 330,000 second
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    can a dti engine be easily changed for a cdti?
    not easily no....but there are plently of cheap DTi engines on Ebay to swap straight in..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Any engine can be re-built, if the parts are available. Some are more difficult than others though.
    They are chain driven and the chain has no service interval. Basically change it when it rattles.
    You can't easily swap for a CDTi - they are totally different animals.
    If the engine is fooked, the cheaper option may be to get a replacement long engine and swap the fuel and ancilliary systems from your old lump.
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    id be sorry if i found a CDTI lump given the amount of posts on here ,people have had loads of hastle with them albeit there quicker, ive driven a2.0 DTI for 9 years (vec b and vec c) with minimal fuss
    Belfast
    Yeah, the DTi is a considerably better lump as far as reliability goes. The swirl valves work for a start...
    Nov 2007
    Chesterfield
    timing chain broke .................................................
    EVERYWHERE
    Do the DTi's have an 'interference' top end ?
    Belfast
    Yes, all diesels do due to the compression ratio. Plus the DTI is a 16v engine with a single cam, so usually the cam rockers break first. The Valves are usually fine if the chain goes at low engine speed.
    But, considering the miles it's probably just easier dropping in a replacement engine, there's lots of them about.
  1. Engine change woes
    By zymon in forum Engine & Drivetrain
    Last Post: 5th October 2012, 22:07
  2. More AC Woes...
    By Munkey in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 17:59
  3. Mot woes!!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2010, 10:14
  4. air con woes
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2008, 19:23
  5. More Woes
    By VauxVeteran in forum General Chat
    Last Post: 15th April 2008, 23:52
