Thread: Urgent rear brake help
    north east
    Default Urgent rear brake help
    Hi guys hope you can help.
    im doing the rear pads on my dti
    and i was winding the piston clockwise for ages and nothing was happening, so i turned it anticlockwise and the piston came out further so now i knew i was going the wrong way so i started going clockwise but the pistonstopped turning and seemed to seize, i can unscrew it but not screw it back in any help appreciated as ill have a long walk for the school run,
    thanks ian
    Sunny Dartmoor
    The piston needs pressure for it to wind back,if you're using the wind back tool it should do it automatically,but if you're not then you need to use a bit more pressure and maybe a bit of wd40 to help it move freely......
    north east
    Hi m8 thanks for quick reply im using circlip pliers and it was moving free but not inwards my pads where down to th emetal so i suspect the piston has came out to far and maybe cross threaded, im phoning around now for a propper tool. tried g clamp and twisting but its solid may need to back it off and try again
    cheers for reply m8
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    I used circlip pliars too m8 and as glen said just give it a push.. pressure is the key
    Quote Originally Posted by tommoturbo View Post
    I hope you haven't stripped the thread - it's really easy to do if you don't use the proper windback tool. Here's hoping you haven't!
    north east
    hi guys thanks for the help.
    i found a local motorfactor that hired out the wind back tool, made sure it was the right size, cycled the 4 mile there and 4 back. only to find none of the attachemnts fit .
    well i tried again eventually it was a case of trying to locate the threads and using windback tool without the adapter on and the circlip pliers, once ir was located it went back ok. did the other side no probs.
    My pads were down to the metal so the piston was right out.
    its took me 5 hours to do a 40 minute job.
    only thing now is my brakes are reall spongey and prob need bleeding
    ill do it later sigh!
    Thanks again for help
    Cheers ian
  1. urgent brake fluid lid req bradford
    By hairy31 in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2012, 10:12
  2. Urgent help - brake pad rewind help
    By JACKALG1 in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 14:54
  3. Help urgent. Rear ARB Bushes
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2011, 13:32
  4. Rear shocks Urgent
    By jlock in forum Suspension, Wheels & Brakes
    Last Post: 2nd November 2009, 23:34
  5. Brake rewind tool URGENT!!
    By Tony12 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2008, 18:50
