Results 1 to 10 of 16
Thread: Hints please on changing headlamp bulbs
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Hints please on changing headlamp bulbs
    Facelift 2006 1.8 model.....
    I know that I will need to lift the battery cover, and remove the neck of the washer bottle on the near side,
    What about the off side? can you remove the air inlet hose, the air filter box itself?
    how do the covers come off? any tips for removing the clips without loosing them?
    Regular Member Harry's Avatar
    Uxbridge, London
    i'd leave the airbox alone on the offside and just work with the space that you've got. just remember that the headlamps twist out of the housing, there are no retaining clips to worry about, until you get the bulb out of the holder that is.
    Regular Member johnnyg's Avatar
    May 2007
    manchester
    take the air box out mate it take 2 mins you will not get your hand in there unless you are sooty .just undo the jubilee clip and lift it out
    Regular Member shan's Avatar
    I got my hand in no problem behind the headlight and in front of the airbox. And i've got hand's like shovel's.
    wales
    same here did not take anything out just rubber covers off andgot at them easy or if you still cant do come to wales and ill change them lol
    Oct 2007
    south wales
    Quote Originally Posted by julls View Post
    Hey whats that supposed to mean? I am Welsh you know in case you didnt see my acvatar....
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    i found it easier to leave the airbox in place, but to disconnect the air feed from it
    this just requires undoing two jubilee clips, and opens up enough room to get your hand in without scraping your knuckles.
    Passenger side you remove the filler neck bottle by just pulling it out with brute force to give you more room.
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I got my hands in ok but do give yourself plenty of time and be prepared for skin loss from knuckles etc.
    Its slightly worth it though if your replacing with better bulbs
    As above, man up and just get stuck in there dude...
    sorry but unlike some others in this thread, my hands were simply too large to fit down there
    Obviously i speak for myself here, and not the rest of you in this thread with ladies hands
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Headlamp Bulbs
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 11:22
  3. F*£$%^^ Headlamp Bulbs
    By Caterman in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2006, 17:46
  4. headlamp bulbs
    By Dave F in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2005, 16:00
  5. Headlamp Bulbs
    By ion in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2005, 07:59
