Thread: Electric Windows not responding
    Scotland
    Question Electric Windows not responding
    Hi Guys,
    First post here, just found this forums by accident, i have been reading through a lot of the posts but I can't seem to find anything what I'm looking for.
    I have an '04 Vectra 1.8i LS, about 8 months ago the passenger side front electric window control stop responding on occasions, if you fiddle with it for a while pushing it down and releasing it it seems to work. I never paid any attention to the problem as it could be controlled from the drivers side but now the drivers side is starting to do the same thing.
    Does anybody know it this is a known issue and can be fixed by cleaning connectors on the control unit or do I need to replace the control unit?
    So I guess I would like help with the following questions:
    1. if it can be fixed by cleaning connectors, How to I remove the units for cleaning, what parts do i clean and what do i clean them with?
    2. if I need to buy replacements, any idea on cost and where is best to get them and how to I change them over?
    Any help would be appreciated.
    Thanks,
    Mark L
    *EDIT*
    Forgot to say the forums are great by the way
    May 2008
    Tyneside
    Had the same problem on my passenger side switch. I removed the switch and squirted some switch lubricant / cleaner into the switch ( no need to dismantle it) then operated it firmly a few times and hey presto it worked. Trouble is because the switches are not used very often the contacts oxydise. Doesn't take much to stop 12 volts. HTH
    Scotland
    Tridley,
    thanks for the quick responce, I guess they just prise out the door handle without to much trouble then?
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    also try the multiplug into the door i had problem with rear drivers side turned out wires had broke on mine.
    May 2008
    Tyneside
    Just use a small srewdriver or blade to prise them out. Think there's a little recess to get a screwdriver blade in.
    Scotland
    Quote Originally Posted by craigbarlow18 View Post
    Quote Originally Posted by tridley View Post
    Nice one folks,
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I did sim issues, dirty connectors in the door switch module
  1. electric windows help
    By leedslads in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2012, 17:37
  2. Electric windows
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 20:10
  3. Electric Windows
    By jctjohn in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2011, 15:09
  4. electric windows
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 22:59
  5. New electric windows anybody !!
    By SCOTTEX in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2006, 14:01
