Ok first post....best option please when fitting panel filter, once I find out which.
Remove trumpet in airbox and fit K&N??? Do I need to reset ECU?
Also what is the air intake mod???
Any help appreciated
Nobody know then?
removing the trumpet in the airbox IS the airbox mod and no there's no need to do anything to the ECU. The air flow meter sorts out that for you![]()
Many thanks Gary, now to find the filter lol
As for the air intake pipe mod read this thread
thanks baz....runs off to pop hood and check
Take off the sensor then unscrew the torx screws on the air box using a t-25 bit, then take off the standard Vx filter and make sure u give the box a good clean and hoover to clear out any crap thats in the bottom. Pull off the trumpet (air box mod) but be careful not to snap the arms coz it can be a little awkward, then just fit the new K&N panel filter and put the lid back on, its that easy!!
Here you go:
http://cgi.ebay.co.uk/K-N-AIR-FILTER...1%7C240%3A1318
spot on...just been out to the vectra and I have the shorter intake already???
53 plate SRi Turbo Edition 100
