Results 1 to 3 of 3
Thread: Changing leak off pipes
    Mar 2007
    dublin
    Default Changing leak off pipes
    Hi all
    think my leak off pipes have had it on my 2.0dti elite, my driveway is upwards and in the morning it starts straight away and then dies, takes a good few turns to fire up again and all is well till next day.
    What is involved in fitting them and does anyone have the part number as my local parts dealers always say oooh its a vauxhall thats gonna make it tricky!
    Flippin opel dealers!
    there's no difference between the opel and the vauxhall, so the parts will be common..
    what you need depends on what you break....as if you break the little plastic tee bits or the connectors on to the injectors you'll be sunk..
    it's not a hard job, just use a pair of small needlenose pliers and be gentle...
    Mar 2007
    dublin
    cheers
    What needs to be removed to change them
  1. Leak off pipes
    By suggs1971 in forum Engine & Drivetrain
    Last Post: 8th April 2010, 22:06
  2. Leak Off Pipes???
    By st2malo in forum Engine & Drivetrain
    Last Post: 17th March 2010, 01:08
  3. leak off pipes
    By Mort in forum Engine & Drivetrain
    Last Post: 7th June 2008, 11:54
change vectra c 2.0 dti leak off pipes
