Results 1 to 10 of 14
Thread: Shocks for a VXR
    Regular Member Netstar's Avatar
    Jan 2006
    South Wales
    Default Shocks for a VXR
    I have a problem
    At the last service, they discovered that the 2 front shocks are leaking fluid and need replacing
    I've been onto VX Cust Services, but its a no go on the goodwill gesture as they have covered 42k
    So, instead of paying the £780 they want for 2 standard VXR ones and springs, what other options do I have? Anyone know?
    I know that the big VX tuners like thorney, courtenay etc use KW Varient's, but i get a bit confused as the suspension (in standard) stiffens up when the sport button is pressed. Does anyone know if this feature will be lost if I use aftermarket ones? Doesnt matter really, but i'm worred that it might cause problems.
    Also, can anyone recommend some good shocks that will work on the VXR and provide links to websites?
    Ta muchly
    Matt
    Sunny Dartmoor
    Think spoons used 888,might be worth giving them a ring....
    you will need their(vx) shocks for the IDS to work...without it it will flag up a faultlight..., so VX is the best way to go...you can leave the standard springs on, unless you're desperate to lower it, but even then it'll only be a smidge..
    Jan 2006
    South Wales
    I was worried about that.
    But i want the upgrades as knowing my luck I'll pay VX for 2 new front ones and the ****** back ones will go and I'll be paying out another £780.
    By using aftermarkets, I'll get all 4 changed, which will last much longer for £40 more
    I'm sure that the tuners will have a way around the problem.
    Looks like I'm going to have to have a chat with them to find out.
    Thanks guys.
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    Is there no way of servicing the originals (new seals etc) as shelling out nearly £800 is shocking.
    Jan 2006
    South Wales
    Unfortunatly not mate.
    They are sealed units and would probably kill you trying to take them apart.
    Hey ho, nevermind, These will be winging thier way to me by the end of the day
    http://www.thorneymotorsport.co.uk/p...oducts_id=2662
    Sunny Dartmoor
    That looks a nice peice of kit m8,coilovers on a VXR,sweet.....
    Jun 2007
    driffield
    They look nice mate not bad price either.
    Do you get any sort of noise from the shocks that you have on at the moment like a rattle or bumping?The noise that comes from mine is awfull really starting to drive me mad.I am thinking about getting some dap springs to see if it tightens it all up as i have heard it does make it better.
    Jan 2006
    South Wales
    yeah, i do get a bit of noise from them, but i just assumed it was due to them being cold as it seems to fade once she's been driven for a while.
    Maybe this is normal, but it turns out they are p1ssing fluid
    may want to get yours checked, just in case.
    spoons
    Guest
    I've got standard VXR Shocks on the car with DAP Racing Springs. DAP Racing springs are much better than the 888 Eibach setup. The DAP front height is fractionly lower than Eibach, but made a huge difference in handling...
  1. what are the best shocks?
    By paul.sessions in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2010, 20:24
  2. what shocks and where from?
    By hagga in forum Handling & Braking
    Last Post: 22nd January 2009, 23:01
  3. vxr shocks
    By Matty1979 in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2009, 11:47
  4. sxi and sri shocks
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2009, 02:14
