Thread: rough idle
    GLASGOW
    Default rough idle
    Wonder if any of you guys have any ideas. Car runs fine until stationary then when ticking over seems to fluxuate between 600 and 1000 rpm, and ocasionaly cuts out when comiing to a stanstill .Cars doneabout 10000 miles 2.0turbo . need to go out right now but be back on in about an hour thanks.
    Jul 2006
    Dirty idle valve?
    Carp in the airbox?
    GLASGOW
    Thanks i wil check that out. If that does'nt work i will take it into stealers as it still has 2years left on warranty . Where is the idle valve .
    remove the black plastic cover on the front of the engine, then remove the air intake hose...clean up that butterfly valve you see with carb cleaner till it's lovely and shiney....
    The 2.0T doesn't have an idle valve as such, it uses the stepper motor to control the idle via that butterfly..
    GLASGOW
    Got car back from vauxhall today said they put new coil pack on and changed spark plugs. Seems to be idling fine now . They never gave me a note of work carried out, so when i asked for one they said they dont normally give out a copy because the work was done through warranty ,but because i asked they said they would send out a copy..
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by ERIC View Post
    If you ask nicely they will do you a print out of all work done on the car from new, as long as the work is done in a VX dealer everything in on there including services, job numbers and costs are also on there.
  1. 2.8T rough idle
    By donkmeister in forum Engine & Drivetrain
    Last Post: 5th December 2012, 12:07
  2. rough idle
    By ianm59 in forum Diesel Engine related
    Last Post: 17th February 2010, 17:59
  3. Rough idle on 3.2
    By rayvo-gsi in forum Engine & Drivetrain
    Last Post: 23rd February 2009, 18:04
  4. Rough idle on GSI
    Last Post: 18th April 2008, 17:41
  5. CDTI 150 rough idle
    By POAH in forum Engine & Drivetrain
    Last Post: 13th November 2007, 17:19
vectra c rough idle
