Results 1 to 10 of 13
Thread: Lowering springs and LPG
    Regular Member jamesr's Avatar
    Lancashire
    Default Lowering springs and LPG
    I have just managed to snap a front spring - so now looks like the best time to fit lowered suspension
    The car is a GSi so already 15mm lower than standard.
    My question is:
    Without changing the shocks is 30mm or 45mm better to go for?
    And becausr of the extra weight in the boot due to an 80 litre LPG tank, I wanted to try and level up the ride. I notice that they do a 45mm front and 40mm rear kit but its not listed for the 3.2?
    Any help appreciated
    Sunny Dartmoor
    Eibach's 30mm kit would be the better option james,but alot of members have put the 45mm kit and had no problems,so if you trust your shocks go for it.....
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Hi mate im looking to get LPG fitted to mine.
    if you dont mind me asking how much did you pay and is it worth it.
    does that car still work as well?
    Lancashire
    Thanks.
    But how do i get a level ride? due to the back effectively carrying +100kgs extra?
    Lancashire
    Quote Originally Posted by Sean-2.2Direct View Post
    PM sent
    Sunny Dartmoor
    I think i remember reading that with the eibach kit you get a better level ride than with the standard one's,but don't quote me on that.......
    Belfast
    You also need to check that your LPG tank stays the correct distance off the ground when you fit lowering springs. I seem to remember there being a minimum distance off the road for the tank.
    Lancashire
    The current gap between the rear wheel and arch is 2 fingers deep.(1-1.5")
    The front wheel gap is as high as a fist? (6"?)
    This is what I want to get rid of? Could I just fit 45mm lowering springs to the front and leave the rear untouched?
    Belfast
    Probably best to fit a kit that'll lower more at the front than the rear - I wouldn't fancy fitting half a kit.
    The Eibach Sportline's drop 50mm front, 30mm rear. I had a Weitec Ultra GT kit on my Mk4 Astra which dropped 55mm front 20mm back, it worked very well. It came with shortened dampers and all. I think they do the same kit for the Vectra.
    Lancashire
    Some sites are listing the 3.2 with two front axle weights?
    1060kg
    1130kg
    Also saw these: http://www.europerformance.co.uk/pag...roduct=3751965
    Could fit these the raise the rear?
  1. lowering springs
    By mvl41183 in forum Handling & Braking
    Last Post: 23rd December 2011, 23:20
  2. lowering springs
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 14:56
  3. Lowering springs...
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 23:33
  4. Lowering springs
    By parsco in forum Handling & Braking
    Last Post: 14th September 2010, 21:50
