Results 1 to 10 of 16
Thread: losing power
    Roja
    Unhappy losing power
    I have 2004 Vectra with 2.2 DTI and have problem: loosing power, and rpm can't get more then ~2700. Exhaust emission lamp is lightning. If it's happened, then there can help restarting engine only. It's happening more with warm engine.
    I get 2 codes: p0105 and p1105
    Before I changed Air flow meter.
    Now changed MAP (used - I'm not 100% sure about working) and repaired Alternator, but It didn't help.
    I discovered there was bearing ball in MAPs tube, to close tube
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P1105 Dual Alternator Upper Fault
    HTH M8y
    Roja
    As I said:
    Changed MAP (used - I'm not 100% sure about working) and repair Alternator, but It didn't help
    Today I'll recheck the codes.
    Nov 2007
    yeah recheck incase its a new fault code. Also maybe it didnt help because
    ''(used - I'm not 100% sure about working)'' Just a thought
    Roja
    if I'm correct MAP is for turbo.
    But why I can't get rpm higher then 2.7-2.9k? I'm driving like on 0.9 diesel motor with one cylinder, without turbo. I can make drag race with school bus - he will win.
    Nov 2007
    Is it going into limp home mode?? Just wondering if it can be something as simple as o2 sensor or EGR value
    Roja
    Local Opel dealers are so smart as died polecat. I'm using my own cable to computer, but it showed just those mistakes. Today will check again.
    Roja
    Is it going into limp home mode?? - how to check?
    Nov 2007
    Car with a spanner through on your engine management screen on your speedo in the rev counter.
    Roja
    No, this is not showing. Some time ago then Exhaust emission lamp switched off , simetimes showed "Car with a spanner through". But not now.
  1. Losing power*
    By Iezzi-martin in forum Engine & Drivetrain
    Last Post: 27th October 2010, 09:40
  2. Losing power!!
    By bigjjfaetheyy in forum Engine & Drivetrain
    Last Post: 14th May 2010, 08:57
  3. Help Car Keeps Losing Power
    By gregc in forum Engine & Drivetrain
    Last Post: 20th August 2008, 01:07
  4. sri 150 losing power
    By marky2027 in forum Engine & Drivetrain
    Last Post: 25th July 2007, 20:09
  5. Surging and losing power.
    By AndrewTi in forum Engine & Drivetrain
    Last Post: 24th March 2007, 19:05
