Results 1 to 10 of 18
Thread: boost sensor location?
    chesterfield
    Default boost sensor location?
    2.2dti 52reg vectra
    just cleaned what i thought was the bost sensor but i think it may be the wrong thing?
    it had 2 pipes on topand one at bottom
    one of the top pipes went direct to boost regulator on turbo
    any pics of the boost sensor would be great many thanks
    Devon
    100 Post(s)
    Vehicle : insignia
    Trim : irmscher
    chesterfield
    Quote Originally Posted by bigmac View Post
    cheers mAte
    Devon
    100 Post(s)
    Vehicle : insignia
    Trim : irmscher
    According to haynes the charge (boost) sensor is located in the intake housing on the inlet manifold
    chesterfield
    is there a pic of it?
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    if you take the cover off ya engine and post a pic i'll circle it for ya. Dead easy to remove and clean. Just be gentle! If ya havent got a pic its a little square box thing bout 1.5 inches long with bosch written on and has 1 torx bolt holding it in. When you undo that and pull it out it'll have a rubber seal attached to it and a cone like plastic bit which houses the sensor and may be full of black crap. Clean it out and you should see a little (orange IIRC) oval thing bout 4mm long inside. Thats the sensor just gently clean all the black gunk away and refit. HTH
    p.s its near the right hand hose
    chesterfield
    Quote Originally Posted by steve View Post
    cheers i will have a pic took tomorrow if i cant locate
    thanks for fast reply
    Nov 2007
    a pic for ya m8y - the sensor is the little yellow bit that cone pastic housing may be full of gunk
    chesterfield
    Top man many thanks
    Birmingham
    whats the best way to clean this??..what products and tools are required to clean? and do i need to be incredibly delicate?
  1. egr and boost sensor location (with pic)
    By frasedeb in forum Engine & Drivetrain
    Last Post: 21st May 2012, 21:04
  2. pressure boost location.
    By leeson in forum Diesel Engine related
    Last Post: 18th September 2010, 21:29
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. Location of boost valve
    By broadgates in forum Engine & Drivetrain
    Last Post: 19th April 2009, 20:45
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
