Hi All, Can anyone please tell me whether the front fog lights come on when you put the high beam on, or is there a seperate switch for the front fog lights, The car is a Signum elagance 2005 plate
Cheers Tony
Cheers Tony
The fog light switch is by the main light switch you press it in when you have the lights on. I can not remember if you need just side lights or the head lights on, as I don,t use mine that often.
Front fogs will work with the side lights on, and dipped or main beams.
If they only came on with main beam headlights, then they'd be called spot lights - not fog lights.
Thanks both for your replies. The other question is are there any driving lights on the signum that come on when I put my high beam on?
Tony
No. just the main and dip lights will be on, unless you also press the fogs to come on too. Though I don,t recomend driving with the fogs on if there is no fog, as the police could pull you over.
OK thank you Ed
regards Tony
