Done the 314mm Upgrade yesterday (Thanks LMF & Tyreman) But now the "ABS" Light is on and stays on....Aghhhh!!! Please Help !!!
Did you reconnect the ABS plug properly?
"ABS PLUG"Don't remember unplugging anything
I thought the ABS wire is straight into the HUB
"Runs outside to check"
are the abs contacts clean. Have you damaged the abs wire??
Have you disturbed the abs wire or anything removing the caliper carrier??
No wires were disturbed,the brakes were bled with the engine off and the the ignition was off any time the wheels were spun,basically done the same as mine but Dave has a light on and i never have!,any ideas?.
Bit of a mystery then. I wonder if disconecting the battery for "say" half an hour might reset any fault that might have been thrown up. I know with my wifes Vectra B, some times when I drive it and move the seat back the ABS light comes on, but when I press the brake and drive forward the ABS light goes out. ?
Sounds like we can not fault your workman ship then. You have done the disc mod correctly then.![]()
PROBLEM SOLVED
A quick trip back to Petes Workshop (Driveway) solved it.....................
While the Wheels were off yesterday, I APC'd and cleaned the arches, with Just a Karcher Brush and Hose pipe has I have done for the last 3 Years....... and for some reason...some dirt, water, grit, or micro organismhad managed to get in the connectors...so a quick blast of Electrical cleaner in all connectors managed to clear whatever was in there,
Bit dissapointing as these connectors are exposed to all the elements of normal driving conditions in Rain Mud Snow eTC eTC throughout there life, but it looks like ASDA APC is just to potent![]()
Cheers Pete![]()
