Thread: clutch has gone very soft
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default clutch has gone very soft
    can anyone enlighten me as to what has just happened to my car.
    i pulled up at some traffic lights and put my clutch in, clutch was done for 1-2 seconds when i heard a snap (sounded like plastic snapping). i didnt know what it was, no warning lights came on, the car didnt do anything. so i pulled away, and as i lifted the clutch and then changed gears the pedal felt really soft. the car didnt pull away any different and it doesnt change gear anydifferently. it just feels as though there is less force behind the clutch pedal returning it to rest position.
    has anyone had this before?
    ill be doin a bit more driving later tonite, so i will be able to feel any changes a bit more.
    any help would be great.
    thanks
    carl
    Purely a guess - but some part of the clutch spring come loose/broken? Can you look behind the pedal to see anything?
    Ashington, Northumberland
    Quote Originally Posted by carl bear
    thanks
    carl
    Sounds like the return spring has snapped. The reason the clutch still works ok is because the pressure plate fingers are acting as the return spring. You will also find that your Cruise Control won't work. Don't know what year your car is, but there is/was an issue with weak clutch return springs on the C's. If your still in warranty period they'll sort it. HTH
    EDIT Duncan beat me to it
    correct me if iam wrong but it sounds like the clutch adusting its self
    this is how fords's do it.(well mine used to)
    mines a 53 plate.
    thought it might of been something like that but wasnt sure. ill have a look behind to see if i can see anything.
    thanks for the help
    carl
    Quote Originally Posted by GARY3306
    lol - but you described it in somewhat better detail!
    Quote Originally Posted by vectra 2.0 t
    Fords used a quadrant ratchet arrangement (bit like a handbrake) to self adjust. When the teeth wore out you would hear a rapid fire of clicks as the teeth glided past each other and the pedal would hit the floor. It gave pretty much the same symptoms as Carl has, but on the Fords that was it, no more clutch. At least with the Vectra arrangement you still have a clutch, albeit that the pedal is not being returned fully.
    Sep 2012
    Norfolk
    Default Weak clutch
    Quote Originally Posted by carl bear View Post
    thanks
    carl
    Hi
    Did you ever find what was causing it
    I appear to have the same problem with the little extra like loose my clutch occassionly the pedal staying onthe floor
    Sep 2012
    Norfolk
    Hi Carl
    I appear to have the same problem with the little extra like loose my clutch occassionly with the pedal staying on the floor
    regards Chubbs
    mine was the clutch return spring had snapped.
    it was fixed under warrenty as it was a problem part apparently and was replaced with an ugraded spring.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. soft clutch
    By myelite150 in forum Engine & Drivetrain
    Last Post: 28th November 2009, 17:30
  3. very soft brakes
    By dodus in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2009, 19:55
  4. Soft Drinks Rip Off!!!!
    By BigMan in forum General Chat
    Last Post: 4th September 2008, 00:47
  5. Am i getting soft in old age?
    By Devil Nev in forum General Chat
    Last Post: 29th December 2006, 21:21
vectra c soft clutch pedal
vauxhall vectra clutch soft
corsa c clutch pedal low pressure
opel soft clutch pedal
clutch gone corsa c
clutch going soft on my vauxhall signum
vx vectra soft clutch pedal
clutch on vectra has gone soft
vectra clutch soft
vectra clutch pedal spring snapped
vectra clutch pedal went soft a few times
