Originally Posted by
Duncan
Hmm, tricky one given what you've said.
The Stage 3 wouldn't void the whole car's warranty, but if you had an issue that they could prove, or simply suspected, was due to any of the Stage 3 then they could refuse to fix that particular bit i.e. if your turbo went, let's say, then they 'may' turn round and say they won't replace it as the S3 was probably a contributing factor - even though it may have been the case that the turbo went if it had been still bog-standard.
It depends on the dealer initialy. My dealer when I had Stage 1 knew of it and had no qualms putting through any warranty work that was obviously nothing to do with the remap.
At the ned of the day they have to know that it has S3. The only thing that is externally visible is the sports exhaust/downpipe/sports cat but as far as they are concerned that could be all you've added. The different injectors are not really noticeable unless you start to take things apart - so it's unlikely they'd know you had anything like that unless there was a more serious issue with the engine and they were taking injectors etc. off.
If you'd had half-leather I'd have said deffo go for the S3, but given what you've said it's what you really fancy/is your main priority and whether you're happy to take a bit of a 'risk' in terms of adding it to a car still under warranty.
