Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: vectra estate front suspension creak?
  1. #11
    Regular Member bigsteve's Avatar
    Apr 2008
    Nottingham
    I wholeheartedly agree coldhand, removing speedhumps would also reduce the carbon footprint significantly!!!
    I have an observation to disclose....after washing my car, the creaking is definitely worse, it is definitely better when dry, and almost non-existent when warm, in fact it all makes sense now, the noise is just like rubber (wet) against steel, however, how can I stop it getting between the rubber and the arb, perhaps some sort of silicone or rubber lubricant could help, any ideas??
  2. #12
    london
    I also have this problem - creaks coming dowm off speedhumps but it is loudest when i'm just leaving the house and almost disappers when i've been driving a while!!! I thought the suspension was just taking a while to warm up :-) I was coming on here to ask the question!! glad to know i'm not alone- but has anyone actually found a solution to this problem yet?
  3. #13
    Anti roll bar bushes are the most likely culprit
  4. #14
    Norwich
    Hi fellas, got the same problem with my 54 plate signum. I took it to the stealers the other day to get them to look at it. They said that the ARB bushes were in good condition with no play in them and I have had the spring mod. After taking the engineer out for a drive over some speed bumps, he was baffled as to the loudness of the creak! He was expecting a quiet creak but when people 20 ft away from us turned and stared at us he agreed it wasnt a normal noise. Its going in again on friday for them to have a poke about and see what they can do.
    Will post again when they have an answer (or not!!).
  5. #15
    london
    Well i'll find out this eve if its was the arb bushes that were squeaking and if it was the drop links giving the clunk as they're being changed as i type. Also had the rear upper arms changed as once i did the test for it (squat facing the rear wheel and pull it hard towards you from the top- movement means they're shot). Found mine were flapping about like dumbos' ears! :-) also changed the rear arb bushes as they're cheap and easy to fit. So hopefully i'll have to get used to the sound of silence! It seems mad that there is so many common faults that make awful noises- though at least they give us a warning!
    so to recap
    front and rear arb bushes
    rear suspension upper arms
    new front drop links
    It had the spring mods in place so if the horrid noise isn't not cured i'll bury it!
  6. #16
    london
    wahey!!! its all sorted- no creaking goining up or down speed humps or taking the short route on roundabouts I will post a new thread to inform others. thanks to all that have suffered before for their invaluable help
  7. #17
    Jun 2006
    Kirkintilloch, Scotland
    Default front spring spring modification
    Quote Originally Posted by parapaul View Post
    First things first - has it got the spring seat mods? If you feel behind the front wheel, in the pan of the shock absorber, the bottom coil of the spring should have a rubber sleeve over it. If not, that's a cheap option...
    Had my front springs replaced last year (under extended warranty) and I see that no rubber sleeves have been fitted. Spoke to the garage this afternoon and they say that the sleeves are no longer fitted.
    Has a further note been issued to not fit a rubber sleeve or can I confidently go back to the garage and complain (preferably being able to quote some sort of Vauxhall reference)?
    Car is a 2004 2.2 elite direct estate.
    Thanks,
    Dave
  8. #18
    Nov 2009
    yeovil
    Default vectra front creaking
    go off and by some spray grease , spray the bottom of the front springs and bushes that has worked for me hope this helps.
  9. #19
    Jul 2009
    sussex
    Quote Originally Posted by delberto View Post
    any update as to what was the actual cause?
  10. #20
    Nov 2009
    yeovil
    i got told by vauxhall that the vectra suffers with the bushes drying out so a quick spray of grease better to jack up the car and let the suspension to drop and there you go hope it works
  1. Replies: 24
    Last Post: 23rd April 2018, 11:01
  2. Strange Creak from Front Suspension
    By eddie twadds in forum Suspension, Wheels & Brakes
    Last Post: 12th March 2012, 21:43
  3. Suspension creak... again...
    Last Post: 29th December 2008, 22:44
  4. A Creak But not Suspension
    By fattony in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2008, 14:29
  5. rear suspension creak
    By chris.100 in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2008, 00:29
vectra c creaking front suspension
why does my vectra c sri estate creak
vectra c sri estate front creaking noise
vectra c top of suspension creaking
