Results 1 to 10 of 24
Thread: MFD incorrect MPG recordings
    Regular Member Teefin's Avatar
    SW Scotland
    Default MFD incorrect MPG recordings
    His Guys had the Vectra a week now and pretty please so far. The only problem seems to be the Multi function display, it has now advised that I was getting 42 MPG and 41.6 mpg between two refills ( 109 miles and 350 miles). However when I have filled up and run a calculation the car is returning 50mpg and 53 respectively (good news I know). Anyone got any suggestions as to why the computer readings are so far out, the mileage is recording accurately against the odometer.
    Any suggestions would be appreciated.
    Mileage : 000
    Do you have a "tuning box" fitted??
    SW Scotland
    No not to my knowledge just bought the car from Arnold Clark and everything appears standard?
    Regular Member shan's Avatar
    It's not normally the car telling lies it normally Arnold Shark .
    Are you sure your calc's are correct the 42 mpg seams a realistic amount for your 1.9 120.
    Jul 2006
    Very unlikely you're getting 50+ mpg unless you drive everywhere at 40mph in 6th...
    greenock
    the odometer reading can be out a little because theres only one decimal place and the only way to know how much fuel u have used is to empty the system and then put in a measured amout then run the tank dry
    working it out urself is full of errors
    Jul 2006
    Quote Originally Posted by ryanhamil View Post
    One decimal place on the odometer is NOT going to affect the MPG figure by over 25%....
    SW Scotland
    Ok will see what reading I get over the next few refills but I brimmed it the last fill and the computer advised I had used 8.6 gallons but 6.2 or there abouts filled her.
    Thanks anyway
    greenock
    Quote Originally Posted by parapaul View Post
    no but i just menat there is still an inherent error in the calculations
    Belfast
    Yep, mine said 37.2mpg and when calculated with the fill it up method I actually got 38.3mpg. They're not the most accurate things.
  1. Incorrect reg on MOT certificate
    By damers2000 in forum General Motoring Chat
    Last Post: 3rd July 2012, 21:52
  2. Two recordings of my exhaust and black smoke
    By george1987 in forum Diesel Engine related
    Last Post: 14th June 2010, 17:28
  3. incorrect postage on parcel...
    By bobby-tupper in forum General Chat
    Last Post: 16th May 2009, 17:20
  4. Politically incorrect….possibly
    By Doug-SRidirect in forum Comedy & Humour
    Last Post: 30th January 2006, 14:35
insignia incorrect mpg display
vectra c mfd mpg
vectra bc incorrect mpg
