Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: The Tuning Box is off and Car is chugging??
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Default The Tuning Box is off and Car is chugging??
    Hi guys, can any1 help here please coz I think im being paranoid?? Basically, 2 days ago I took my diesel tuning box off the engine having read that it can damage the injectors and fuel pump if used over a prolonged time! Now since taking it off the car it has felt a little hesitant and on occasions feels like it is chugging, coffing and spluttering. Earlier this evening I popped out to see my m8 and the car was doing the same, so I gave it a bit of throttle to try and clear the crap but the spanner light came on the dash I lost some power then it went off again, im confused??!! Now, I know a tuning box increases the fuel and air mix to create the extra power, but could the car not have reset itself after iv taken the box off causing excess the not fuel to be used, hence the hesitance and spanner light??
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    does it not take an average drive to compensate the new values..... just a thought
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Maybe disconect the battery for 30mins so everything is wiped clean then reconnect then the system starts a fresh and is not looking for the box.
    Just a thought
    Jan 2008
    South Wales
    Ye I know where ur coming from but I put it on and take it off regularly coz iv read so much stuff about them, this is the first time this has happened tho!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    To reset it you will need to disconnect the battery for 2. mins. This will also clear any fault codes stored.
    edit: Far far to slow!
    could it just be a coincidence?? does it run better once plugged back in
    Jan 2008
    South Wales
    Ill try the battery thing in the morning, but im doubtful it will work coz a tuning box only intercepts the info from the ECU and changes it before sending it on to the engine!
    May 2007
    WINSFORD
    Maybe your EGR has packed up
    Jan 2008
    South Wales
    Ye mayb ur right rushy, it could be the fault codes thats causing it! What u mean by (edit: Far far to slow)?
    Jan 2008
    South Wales
    Quote Originally Posted by ANDY W View Post
    EGR valve, whats that?
  1. 150 chugging
    By skene in forum Engine & Drivetrain
    Last Post: 5th December 2012, 00:12
  2. My 2.2 is chugging going into 2nd gear:(
    By Jojow in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2011, 20:40
  3. My 2.2 is chugging going into 2nd gear:(
    Last Post: 15th August 2011, 20:39
  4. Blue smoke/Chugging!.
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 18:21
  5. Chugging 1.9cdti
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 9th May 2011, 16:40
