Results 1 to 3 of 3
Thread: cambelt change?????
    Regular Member dan1983's Avatar
    North London
    Default cambelt change?????
    Hi my car has started getting quite loud in the morning when first starting it up, it sounds like the cambelt. the car has only done 47000 miles. can i just tighten it or does it need changing, also how much $$$$$$.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    hello mate your car doesnt have a timing belt it has a timeing chain ..it is normally the chain that rattles on start up ..i would get it checked ..try www.z22se.co.uk for more info ...i know it isnt your engine but there a close match and the chain problem is the same ... ...hope this helps benny
    It's unlikely to be the timing chain, they're not a known issue on the 2.0T.
    What it is most likely to be, given that it's a 2.0T, is one, or a combination, of multi-v belt tensioner and/or alternator pulley - the latter of which was modified so any of these you buy now will be modified. It's such a common problem on the 2.0T that it's more than likely to be that.
    There are numerous threads on here about the issue - several by me! lol - just search for multi-v tensioner or alternator pulley and you'll dig up a few threads.
    Is the noise a kind of 'twittering' noise when you first start up and it goes away after a minute or so?
  1. cambelt change
    By chappie in forum Introduce yourself.
    Last Post: 28th April 2009, 07:48
  2. DIY cambelt change
    By bigcarman79 in forum Engine & Drivetrain
    Last Post: 14th May 2008, 20:31
  3. 3.2 cambelt change
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 12th May 2008, 21:46
  4. Cambelt change £140-160
    By jamesr in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 11:46
  5. cambelt change
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2006, 04:02
