Results 1 to 10 of 16
Thread: crazy idea...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default crazy idea...
    I know that this might be a problem on my car as i have front foggies allready...
    but its retro fitting AFL but its not the headlights that turn... but front foggies that turn on at the correct side..
    hella made a set.. so if i dint have foglights it would be easy to do is...
    http://www.hella.com/hella-com-en/774.html
    its the dynabeam im thinking of.. (evo2 of it).
    i have a few questions for you electric gurus... where can i find the speedsensor that i can use... (mine a 2004 half canbus).
    how much needs to be changed... when i want to use my original foglights?
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    there is a speed sensor wire in the radio wiring,as to another thing that you may have not thought of,how do you intend to get the steering angle so that the headlights turn when you want them too?
    Engine : 2.2 Direct
    i was thinking of using the set from hella and modify that.. and use my foglights...
    the hella set is using the turnsignal as signal to turn the light on.
    Wich wire is it? (cdr2005)
    Engine : 2.2 Direct
    but one of my problems (in my head) is will it work.. as i wont be usingthere foglights or there swich in the set.. but want to use my original ones..
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Why dont you piggyback from afl lights? alternatively, look at the wiring on the afl lights and compare it to your current lights, look at the wires which go to the motors and devices that change the beams
    Engine : 2.2 Direct
    its not the original opel/vauxhall afl... but "afl" that uses the foglights..
    dont have enough money to buy original afl..
    Jul 2006
    Northampton
    Trim : Sri
    Well if your going to fit them you will need some sort of positional sensor for the steering movement and i would suggest to use the speed sensor from behind the radio, you can get from inside the car to the engine bay behind the glove box. you can piggyback from this wire or if you have an aftermarket stereo, it probably wont have a use so just pull the wire out of the iso.
    Engine : 2.2 Direct
    please look at the link to hella then you understand..
    Jul 2006
    I understand - but can't see how it would work.
    You want to use your indicators as a signal to activate the AFL - but that would mean you only ever got the light when you were turning at a junction, and not on every corner where you need it.
    How do the cars with standard AFL generate a signal to tell the beams which way to bend? I would assume some kind of angle sensor on the steering rack or similar...
    Good luck, I look forward to watching this progress
    Engine : 2.2 Direct
    Quote Originally Posted by parapaul View Post
    yes i want to use the indicatores.. as trigger... know it will only be at junctions...
    I
    yes the standart AFL use a angle sensor..
    it was this part i was after for the car.. but the few problems described.. as i allready has fogligts ect.
    http://dynaview.hella-online.com/COM/site/index.html
    would love this one.. but will not try to install that..
    http://dynabeam.hella-online.com/COM/index.html
  1. Crazy idea
    By fattony in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2012, 22:10
  2. Crazy people, crazy drivers.
    By Grumpy1954 in forum General Chat
    Last Post: 8th October 2010, 19:42
  3. OK, Got another crazy idea POLL
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2006, 01:34
