Thread: prolems after service
    UK
    Default prolems after service
    just picked my car up for having a service
    oil + filter
    air filter
    fuel filter
    etc
    and it does not seem to accelerate until the revs get over about 2.5k, run it until warm and still the same then spanner light came on.
    Any ideas what they could have done?
    Surrey
    What engine?
    UK
    oh year that might help sorry
    its 1.9 cdti 150bhp in a 56 reg vectra estate
    Jul 2006
    Quote Originally Posted by marley View Post
    That sounds like something to do with the turbo to me, that's about the point where the turbo's usually spooled up.
    Hopefully completely unrelated to the service you just had, but I would start with your boost hoses and check for splits
    UK
    confused
    Turbo seems fine as the lack of power is mainly before the turbo spools up then it pulls ok'ish.
    Took it back to the garage this morning, they plugged it into the computer and it showed an unknown fault. After a few test drives the problem seemed to clear its self however when i picked the car back up it was playing up again. I pulled over switched off and on again and then it drove home fine.
    The garage suggested it might be the airflow meter so ive pulled it off and given it a clear out as there was some dust and dirt in it, given it a thrash around for ten minutes and all seems fine.
    If the problem comes back again i'll fit a new air flow meter and see if that helps.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would have said that it was the mass airflow meter. Have they clipped everything back together correctly when they done the air filter? Maybe the plug into the MAF is not fitted correctly
    Jul 2006
    Sounds like a lucky - and cheap escape then
    Hope it stays fixed!
  1. Replies: 341
    Last Post: 20th April 2016, 06:29
  2. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  3. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
