Thread: Drivers electric door mirror
    Regular Member ben and ellies dad's Avatar
    Birmingham
    Default Drivers electric door mirror
    Can anyone help with this...
    When I press the 4 way switch to tilt up the mirror moves up AND out! Tilt down moves the mirror down AND in! 4 way switch pressed left moves mirror in AND down and vice versa for pressed right. I am confusing myself even as I write this. Can anyone make any sense of it? I have replaced the mirror motor unit to no effect.
    Birmingham
    bump
    Administrator plasma's Avatar
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    could be the switchpack or the door module, you'd need to either swap with someone else to test it or get a local independant garage with a tech2 to test it for you
    Birmingham
    tech 2 shows switch working ok so maybe a door module(gulp)!
    On the Forum
    572 Post(s)
    Engine : 150
    Mileage : 74000
    bout £80-£90 or so plus another £40-£60 to tech2
    What spec car you have, i may be able to source you one... ic you have the design. So the mirror is purely an electric one.... In that case you have pm
    Mileage : 000
    Are you by some chance pressing the switch diagonaly, ie in the corner so as not to be directly pressing up. down. left,right. Just a thought.
    Birmingham
    Thats what I thought! As it happens, you cannot do it and tech 2 shows the switch working ok. Somehow the signal to the door mirror motors has gone weird
  1. Drivers Electric Mirror Not Working
    By Gogs67 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2012, 23:14
  2. Electric auto folding drivers door mirror
    By lofty in forum Parts for sale
    Last Post: 27th July 2009, 15:33
