Thread: Power steering fluid - which one?
    Regular Member danlat1415's Avatar
    Lancashire
    Default Power steering fluid - which one?
    I keep getting the power steering warning light on the dash, and think i may have a leek with the power steering fluid, so i'm going to take a look tomorrow.
    If I need to top up the fluid, apparantly it: CHF - Central Hydraulic Fluid that needs to go in.
    would this be ok?
    It's CHF 11S....
    I've got my MOT on Monday, and want to disguise any leak so I can fix it later rather than fail the MOT.
    Dan
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    VX say use part no. 93.160.548,, Google search revealed:
    http://www.partsforsaabs.com/product...roducts_id=122
    or flea bay http://cgi.ebay.co.uk/VAUXHALL-POWER...80817094a13143 but the postage is horrendous
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    yes m8 thats fine as i have that exact one in my pump
    Lancashire
    Instead of using the bottle shown above, would this one be ok? It says it stops leaks, and due to me needing some, I'm guessing it's got out somehow...
    (I haven't got round to doing it yet, due to dark nights and cold days.)
    http://www.halfords.com/webapp/wcs/s...Id_165750#dtab
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by danlat1415 View Post
    IMO, no. Stick to what's tried and tested/recommended. So CHF or VX / Saab stuff.
    Regular Member denzo's Avatar
    Runcorn
    I thought we had to use the green one?
    Lancashire
    Just to clarify....
    So this is a completely different type of Power Steering Fluid, and not like an additional fluid to help stop leaks etc?
    (like engine additive which you add to engine oil - and fuel injection cleaner which you add to fuel tank..)?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Just to clarify....
    Correct (I believe). For the sake of an extra £7ish on top of the Slick 50 price, I'd play safe and get the proper stuff from VX or go mail order. Don't know what damge (if any) long term, an incorrect fluid would do to any seals and pipes in the power steering set up.
    Cardiff
    Had a warning today on the dash display to say that the 'Steering Fluid Level' was low. No problem, I popped into Halfords and took a look. There were a few types so I thought I'd consult the chart books they have on the shelves. I looked up my car (52 plate Vectra Diesel Turbo 2.0) and the chart suggests that I use either Castrol or Halfords Differential oil 80/90. I took one of these containers to the counter as I thought it a little strange, the guy initially said it was the wrong stuff, but after checking the same chart as I did, he said yes, thats the stuff you need.
    Is that right? Differential oil in the power steering system? Sounds a little dodgy to me.
    Searched the Net about this, but can't find anything. Can someone please advise.
    Mar 2011
    S
    www.commaoil.co.uk
    You can type registration into this website and it will tell you exactly what fluids your car needs. Comma is what i use as its what we sell where i work.
  1. Power steering fluid.........
    By Sway in forum Engine & Drivetrain
    Last Post: 18th December 2012, 20:06
  2. Power steering fluid
    By Friel in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2011, 23:29
  3. Power Steering Fluid
    By jrwilshire2003 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd February 2010, 16:16
  4. Power steering fluid
    By steven_armit in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2008, 22:24
  5. power steering fluid ??
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2006, 17:14
vauxhall insignia vx power steering fluid
https:www.vectra-c.comforumshowthread.php61625-Power-steering-fluid-which-one
vectra c power steering fluid
vectra c atf oil power steering
vauxhall vectra c power steering fluid
psf vectra c
vauxall vectra 2000 what power steering fluid does it use
vectra power steering fluid
vauxhall vectra power steering fuel
power steering fluid vauxhall vectra
power steering fluid vectra 53
chf 11s vectra c
